How is mass density affected by speeds near c?
  • Thread starter Thread starter elliottmarter
    Density Mass
elliottmarter
basically what is the relationship between mass density at "zero" speed and mass density at speeds nearing the speed of light (0.98c,0.99c etc)
in the form M = \gamma Mo if possible
Thanks a lot guys!
sorry just saw that this should have gone in the H/W section :rolleyes:
elliottmarter said:
M = \gamma Mo
Isn't that the answer to your own question?
well, i mean i took a guess that it takes that form, but is gamma squared or cubed?...anything that could change the proportionality...you know :)
cheers
If by "mass density" you mean "relativistic mass / volume" then yes, gamma is squared:
gamma = 2 means that a moving object has half the volume, but also double relativistic mass, so 4 time more "mass density".
ah i see!
thanks a lot, i think i will be frequenting these forums often in the future
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
