Matter wavelength and indeterminate of location and energy
hubert_g
I have to find matter wavelength and indeterminate of location and energy for hydrogen particle which is in gas with konwn p, V, T
I'm sorry for my english skills:P
pressure will be p_{g}
\lambda = \frac{h}{p}
p = mv
v = \sqrt{\frac{3p_{g}}{\varrho}}
\varrho = \frac{n\mu}{V}
p_{g}V = nRT
\varrho = \frac{p_{g}\mu}{RT}
v = \sqrt{\frac{3RT}{\mu}}
\lambda = \frac{h}{m\sqrt{\frac{3RT}{\mu}}}
m - mass of hydrogen particle, \mu mass of gas particle
Am I doing it correctly so far?
Yes, you are doing it correctly so far. To complete the calculation, you need to specify the values of h (Planck's constant), m (mass of hydrogen particle), \mu (mass of gas particle), p_{g} (gas pressure), V (volume), T (temperature), and n (number of particles). Once you have those values, you can plug them into the equation to calculate the matter wavelength and indeterminate of location and energy for the hydrogen particle.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am looking at the Laughlin wave function and it contains the term $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q$$ In Wikipedia the lower index on ##\Pi## is ##1\le i<j\le N## and there is no upper index. I'm not sure what either mean. For example would $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q=\prod_{k=2}^{N}\left[\prod_{j=1}^{k-1}\left(z_j-z_k\right)^q\right]?$$ (It seems that ##k## cannot be 1 because there would be nothing to multiply in the second product). I'm not sure what else the...
