Quantum:- SHO potential and its energy
indie452
the energy levels of a particle mass in a symmetric 3d SHO potential are:
E = (nx + ny + nz + 3/2)*h-bar*\sqrt{\frac{C}{m}}
C=constant
n=principal quantum number = nx + ny + nz
A) If 10 electrons are in the potential what's the lowest possible value for the total energy of all the electrons?
B) If instead 10 pi- mesons are placed in th same potential what is the lowest possible value of the total energy of the mesons?
A)
for 10 electrons with + or - 1/2 spin the l quantum number is 2 as if the electrons were in an atom there would be s, p, d orbitals
This means that n is and integer greater than 2 [lowest n is 3]
so E = (3+3/2)*h-bar*\sqrt{\frac{C}{m}})
me = mass of electron
= (9/2)*h-bar*\sqrt{\frac{C}{10me}})
i did think that maybe the l quantum number should be 3 but it doesn't need to be in this example it just has 2 as the lowest possible. if all electrons had same spin direction then it would need l=3 due to PEP
B)
would the answer be the same as above? as l=2 but the mass would be 2730me as pi meson is approx 273 times mass of electron
= (9/2)*h-bar*\sqrt{\frac{C}{2730me}})
Consider that the electron is a Fermion and the pi meson is a Boson. The energy levels they can occupy are different.
The atomic quantum numbers nlm don't apply at all here. That's for an electron in a Coulomb potential. In the 3D SHO, the states are labeled by n_x, n_y, and n_z. The ground state would be (n_x,n_y,n_z)=(0,0,0). At the next energy level, there are three degenerate states, (1,0,0), (0,1,0), (0,0,1), and so on.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
