Matrices Proof> C=A-B, if Ax=Bx where x is nonzero, show C is singular
  • Thread starter Thread starter Luxe
    Matrices Proof
If Ax = Bx for a nonzero vector x, then it follows that Ax - Bx = 0, leading to x(A - B) = 0, which can be rewritten as Cx = 0 where C = A - B. Since x is nonzero and Cx = 0, this indicates that the matrix C must be singular. The discussion confirms that the existence of a nonzero solution to Cx = 0 implies C does not have an inverse. Thus, the conclusion is that C is indeed singular. This proof demonstrates the relationship between the matrices A, B, and C in terms of their singularity.
Luxe
Let A and B be n x n matrices and let C= A - B.
Show that if Ax=Bx, and x does not equal zero, then C must be singular.
Ax-Bx=0
x(A-B)=0
x(C)=0
So, Cx=0
Does that mean C is singular?
If Cx=0 and x is not the zero vector, then what would C^(-1)(0) be? C0=0 as well. Would it be x or 0? Sure, it means C is singular.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
