Given conductivity, calculate E, D, and P vectors
aliaze1
The gap between a pair of parallel infinite copper plates extends from z = 0 to z = W > 0 and is originally occupied by vacuum (ε0, μ0). The plates carry equal and oppositely signed surface charge densities and as a consequence we have a constant electric field E = −4ˆz V/m in vacuum in the gap region.
What would be the new equilibrium values of E, D, and P in the gap region if some amount
of salt were dissolved in the fluid in the gap (64ε0) to raise its conductivity to σ = 4 S/m (conductivity of sea water)?
State the values of E, D, and P after a steady-state equilibrium is reached and briey explain your answer.
DE0*E0+P
P=polarization vector
I have the equation J = σE, but I do not know how to relate this to D and P, since I am not given J in the problem
Thanks!
Try to look at this problem qualitatively first. What does Ohm's Law (\textbf{J}=\sigma\textbf{E}) tell you the current will be when the salt is first added? What does that current do to the amount of charge on each plate? What effect does that have on the electric field in the gap?...Can you guess what the electric field will be when equilibrium is reached?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
