What is the correct answer for 3r - 3p + 5q if p = 4, q = -2, r = 3, and s = -5?
  • Thread starter Thread starter Gringo123
    Expression
To evaluate the expression 3r - 3p + 5q with the values p = 4, q = -2, and r = 3, the calculation proceeds as follows: 3(3) - 3(4) + 5(-2) results in 9 - 12 - 10. The correct answer is -13, confirming the math book's solution. The initial miscalculation of -7 arose from incorrect arithmetic in combining the terms. The final evaluation clearly shows that the accurate answer is indeed -13.
Gringo123
p = 4
q = -2
r = 3
s = -5
on that basis, evaluate this expression:
3r - 3p + 5q
I make it to be -7 (15 - 12 + (-10)
But my math book says the answer is -13. Can anyone explain where I have gone wrong?
Thanks
3r - 3p + 5q
= 3(3) - 3(4) + 5(-2)
= 9 - 12 -10
= -13
Thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
