What Determines the Magnetic Field Orientation in a P Type Semiconductor Coil?
The magnetic field orientation in a P type semiconductor coil is determined by the direction of current flow, which remains consistent regardless of whether the carriers are electrons or holes. When a DC current flows, the orientation of the magnetic field can be predicted using the right-hand grip rule, applicable to both metallic wires and P type semiconductors. The key point is that the current direction dictates the magnetic field, not the specific type of charge carriers. Consequently, the magnetic field orientation will be the same for both types of conductors when the current flows in the same direction. Understanding this principle is crucial for applications involving semiconductor devices.
crx
P type semiconductor coil...
The magnetic field orientation in a P type semiconductor wire, in which a DC current is flowing will be caused by the direction of movement of the electrons or the positive holes?
Is this a homework problem? If so please show your attempt at a solution.
no it is not a homework problem...i would say the magnetic field orientation is given by the electron movement, but i need an exact answer and not opinions...thanks
The answer is--it doesn't matter. If holes flow from left to right, the current flow is said to be in the same direction. A current in that direction corresponds to electrons flowing from right to left. It is the direction of current flow that matters, the carriers will sort themselves out.
Thank you Marcus , but this was an opinion...Considering the real direction of the electrons (negative charges), in a metallic wire conductor with the ends connected to a DC voltage, the magnetic field orientation will correspond to the "right hand grip rule". Now if we replace the metallic wire with a P type semiconductor wire (in which positive holes are the major carriers), the orientation of the B vector will be the same as the metallic wire or will be opposite?
The voltage source drives a current in the same direction both times, regardless of the type of carriers involved. Therefore B is the same each time.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
