Fortran Why is my FORTRAN 90 Program Producing Unexpected Matrix Elements?
  • Thread starter Thread starter rizzodex
    Bug Fortran
The discussion centers on a FORTRAN 90 program that generates two matrices, alpha and beta, and addresses unexpected values in the beta matrix. Specifically, the (4,1) element of the beta matrix is incorrectly showing as 5.0 instead of 2.0, and the (5,8) element is non-zero instead of zero. The issue arises from an out-of-bounds write in the alpha matrix due to the loop condition, which leads to unintended modifications in the beta matrix. The problematic line is identified as alpha(4*k+3,4*k+3+5)=5, which exceeds the matrix dimensions when k reaches its maximum value. This results in writing to memory locations that should not be accessed, causing the unexpected values in beta. A suggestion is made to improve code readability by defining an index variable for clarity.
rizzodex
Hi all,
I encountered a problem while running a FORTRAN 90 program, which appears (to me) to be quite surprising. Can someone please explain the following things:
1. Why the (4,1) element of the beta matrix is 5.0 instead of being 2.0 ??
2. Why the (5,8) element of the beta matrix is non-zero instead of being zero ??
Here comes the program with the results at the end:
PROGRAM hamiltonian
IMPLICIT NONE
INTEGER :: N,i,j,k
REAL, ALLOCATABLE, DIMENSION (:,:) :: alpha,beta
COMPLEX, ALLOCATABLE, DIMENSION (:,:) :: hk
N=8
ALLOCATE (alpha(N,N),beta(N,N),hk(N,N))
alpha=0.
beta=0.
hk=(0.,0.)
DO k=0,(N-4)/4
alpha(4*k+1,4*k+1-3)=5.
alpha(4*k+1,4*k+1+1)=5.
alpha(4*k+2,4*k+2-1)=5.
alpha(4*k+2,4*k+2+1)=5.
alpha(4*k+2,4*k+2+3)=5.
alpha(4*k+3,4*k+3-1)=5.
alpha(4*k+3,4*k+3+1)=5.
alpha(4*k+3,4*k+3+5)=5.
alpha(4*k+4,4*k+4-5)=5.
alpha(4*k+4,4*k+4-1)=5.
beta(4*k+4,4*k+4-3)=2.
END DO
DO i=1,N
OPEN (UNIT=10,FILE='alpha.dat')
WRITE(10,100)(alpha(i,j),j=1,N)
100 FORMAT(8(3X,F3.1))
OPEN (UNIT=20,FILE='beta.dat')
WRITE(20,200)(beta(i,j),j=1,N)
200 FORMAT(8(3X,F3.1))
END DO
CLOSE (10)
CLOSE (20)
END PROGRAM
~ RESULTS ~
alpha.dat :
0.0 5.0 0.0 0.0 0.0 0.0 0.0 0.0
5.0 0.0 5.0 0.0 5.0 0.0 0.0 0.0
0.0 5.0 0.0 5.0 0.0 0.0 0.0 5.0
0.0 0.0 5.0 0.0 0.0 0.0 0.0 0.0
0.0 5.0 0.0 0.0 0.0 5.0 0.0 0.0
0.0 0.0 0.0 0.0 5.0 0.0 5.0 0.0
0.0 0.0 0.0 0.0 0.0 5.0 0.0 5.0
0.0 0.0 5.0 0.0 0.0 0.0 5.0 0.0
beta.dat :
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
5.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
0.0 0.0 0.0 5.0 0.0 0.0 0.0 0.0
Technology news on Phys.org
For some reason the above post doesn't have the last row of the beta matrix which is:
0.0 0.0 0.0 0.0 2.0 0.0 0.0 0.0
So, the total form of the beta matrix is :
beta.dat :
This line is probably a problem:
When k = N-4/4 then the second index is 4*k+8 = N+4 which is out of bounds of alpha. So you are writing to something else in the heap which is probably beta. Generally writing out of bounds is a very bad thing, and a variety of strange things can happen as a result.
You're getting a value at row 8, column 5 in your beta matrix because of this one:
When N = 1 the indices evaluate to beta(8,5).
You could make your code a bit easier to read by defining a quantity like index = 4*k+1 inside your loop.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
