Find Velocity for Object to Reach Space & Return in 8 Days
The discussion revolves around calculating the velocity required for an object to be launched straight up from Earth, reach space, and return exactly 8 days later. The participants explore the complexities of non-constant acceleration due to gravitational changes and the effects of air resistance, while also considering the motion of the Earth during this time.
  • One participant notes the need for calculus due to the changing distance from Earth affecting acceleration, suggesting that escape velocity might be relevant but lacks a time reference.
  • Another participant emphasizes the assumption of no air resistance, stating that including it would complicate calculations significantly.
  • A different viewpoint introduces Newton's law of gravitation to derive a differential equation of motion, suggesting that solving it with appropriate boundary conditions could yield answers.
  • Concerns are raised about the drag force at high speeds, with one participant estimating that the required speed might be close to escape velocity, while also noting the complexities introduced by air density variations.
  • Some participants discuss the implications of firing the object straight up, considering the Earth's movement during the 8 days and the necessity of accounting for this in calculations.
  • One participant proposes approximating the path as an elliptical orbit, suggesting that the extra distance around the planet would have a minimal effect on the overall time and velocity needed.
  • Another participant inquires about incorporating distance-dependent acceleration into time-related formulas, prompting discussions about integration.
  • Clarifications are made regarding the assumptions about the Earth's motion and the desired landing point of the object, with one participant stating that they only need the initial velocity and the maximum height reached.
  • Formulas for orbital velocity and the semi-major axis of an orbit with an 8-day period are shared, indicating progress towards a solution.
  • One participant expresses gratitude for the contributions, stating they were able to solve for the velocity and distance, while sharing a link to their results.
  • Discussions about the Earth's movement and whether it poses a problem for the launch trajectory continue, with differing opinions on the significance of this factor.
Participants express a range of views on the assumptions regarding air resistance, the effects of Earth's motion, and the methods for calculating the necessary velocity. There is no clear consensus on the best approach or the significance of various factors involved in the problem.
Limitations include the dependence on assumptions about air resistance, the Earth's motion, and the complexities of non-constant gravitational acceleration. The discussion reflects a variety of approaches without resolving the mathematical intricacies involved.
spl3001
I am trying to find a velocity for an object that would launch it into space from Earth (straight up, NOT into orbit) and return exactly 8 days later. I cannot use x = v0t + 1/2at^2 (x=0 t=691200 a=9.8 [seconds in 8 days]) because the distance from the Earth changes in such a great way that acceleration is not realistically constant any more. I know this would require calculus, but I cannot find a formula or a method. I believe some reworking of
escape velocity would do, but there is no reference to time.
I know this is a very specific question, but any guidance would be a great help.
So, you are shooting it up and waiting for it to fall back down after 8 days...that means non-constant acceleration. I'm guessing you are assuming there is no air resistance right? Air resistance causes terminal velocity. As for the acceleration...its a hard one to figure out because I've never dealt with non-constand acceleration, but if at least you knew how far up it went before coming to a stop, then you could figure out g at that height and average it with 9.8 and use that to plug into an equation. I am not sure if that would get the job done right, though.
Try using Newtons law of Gravitation: F(r)=G\frac{Mm}{r^2}
with r the distance to the center of the earth, G the gravitational constant, M the mass of the Earth and m the mass of the object.
If you equal this force (by using Newtons second law) to ma (assuming constant mass) you get a (differential-)equation of motion:
\frac{d^2r}{dt^2}=G\frac{M}{r^2}
Solving this with the appropriate boundary conditions leads to you answer.
You can use this also to calculate g;
mg=G\frac{Mm}{R^2} so
g=G\frac{M}{R^2}= 9,8ms^{-2}
with R the radius of the earth. By replacing R with your current distance to the center of the Earth you get a distance dependent 'g'.
If you have trouble solving the equation let me know...
If you exclude air resistance (which I think you should, to make things not too compicated :cry: ) you make the 'non-constant g fault' look like nothing :wink:.
Air resistance should be ignored because the amount of time the object will spend passing through the atmosphere is a very very small percentage of the fall time. It spends four days rising and four days falling, and will pass through the atmosphere (say a hundred miles thick with constantly varying density, so air resistance should only be significant in the lower regions) at hypersonic speed in about five seconds. Including subsonic air resistance would be more than a little complicated. I don't even know what it'd look like at such high velocities.
The constantly varying g is much easier to include and is far more important consideration to the final result.
The drag force is proportional to the squared velocity of the object. At high speeds there will be a large drag force decellerating the object. This will have a large effect on the initial speed. To make a guess I think the speed spl3001 is looking for is in the some order of magnitude (maybe one lower) as the escape velocity of the earth. At a speed of 10^5 m/s the drag force is about 5*10^12 N for a (small) object of an area of 1m^2. This is a huge force. And the object has to have a large mass ( in this example >10^8kg) to not be brought to a halt, and then it has to have suffiecient speed to not return to earth. But this leads to very complicated calculations (not in the least because the density of the air depends on height also) so let's stick to the case of zero drag...
Of course if you use some sort of propulsion mechanism during the take-off you can do the problem realistic without using air resistance.
Let us not forget that you cannot fire it straight up because in 8 days the Earth will have moved.
Ha, Good one. I totally forgot about that... :biggrin:
So I guess it's more like a problem to get some practice with calculus, and not solving a very realistic problem. Or if you are getting the hang of it you can ofcourse try to solve it including the Earth's motion around the sun. You also have to take into account the Earth's rotation when you're firing not straight up. And while you're at it you can try to include the gravitational effect of the other planets and sun as well, and...and...
(why isn't reality as simple as in physics problems...?) :cry:
Now that I have a distance dependent acceleration, how do I incorporate that into a formula involving time such as v(t) = v_0 + \frac{1}{2} a t^2?
How accurate do you need to be?
You could simply approximate the path as an elliptical orbit with perigee at the Earth's radius and apogee placed such that the period of the orbit is 8 days. You'll be going fast enough that the extra distance around the planet would only contribute a few minutes to the orbit, and add a few m/s to the velocity.
Integrate... :smile:
spl3001, are you assuming that the Earth is at rest with respect to the sun? Because you said in your first post (straight up, NOT into orbit). Also, does the projectile have to land at the place that you shot it from or does it simply have to go up and down in a straight line regardless of where it lands??
I just need it to land on earth. A straight line up and down would be fine, even a few hundred meters away is ok. I don't really need to figure an gravitational influences from other planets/moons/the sun, and the Earth can be assumed to be at rest. All i need is the initial velocity and the furthest distance from the starting point (exactly 4 days into the trip). I think the orbit idea would work, except I don't have the equations to calculate the period for an orbit, especially for such an eccentric one.
V=\sqrt{\mu*(\frac{2}{r}-\frac{1}{a})}
Where \mu is G*M or 398600.4 km^3/sec^2 for Earth,
r is the distance from the center of the Earth and
a is the semimajor axis of the ellipse.
That might be able to give me the speed. That's the orbital velocity of an object in an elliptical orbit. I need to know the semi major axis of an orbit with a period of 8 days in which its perigee point is in contact with the Earth's surface.
I believe I'm getting pretty close now.
The period of an orbit is
<br /> \frac {2 \pi a^{\frac{3}{2}}}\sqrt{(G m)}<br />
where a is the semimajor axis, G is the gravitational constant, m is the mass of the primary.
I would just like to thank everyone for their suggestions and ideas. It all came together and I was able to solve for the velocity and distance.
Results are here:
http://www.gobean.com/sww_35.htm
Is this really a problem?
I think the Earth and the object would be moving together, so we wouldn't have to worry about that...
If the Earth would move with a constant (linear) velocity, yes... But the Earth revolves in an ellipitical orbit around the sun. So it is not true in this case..
But the object and the Earth would be at the same orbit, since the 4 days distance from Earth is a small value, wouldn't they?
The rocket would have traveled a distance 2\pi R \alpha while the Earth would have moved a distance Rsin(2\pi \alpha ) in the same direction. R is 1AU and \alpha is the fraction of the orbit traveled, so this is 4/365,25. The difference between the two is 5,43*10^-5 R. This amounts to 0,637 of the Earth diameter. So with a little bit of luck it will still land on the surface of the earth. So you are right..
I think we don't need any luck.
Suppose you are at north pole, just to simplify the problem (otherwise, we should add a horizontal velocity component to the launching speed in order to shoot the object in a real radial direction).
Shoot the object straight up. After 4 days the object will reach its max distance from the Earth (a fraction of Earth-Moon distance), and 4 days later, the object will return back to you.
The point is: since the max distance is a small distance, the object and the Earth will be reasonably at the same orbit around the Sun all along, so you don't need to worry about the orbit.
Could you back this up with a calculation?
Of course yes!
I used a numerical method (simplified program below).
Use 52.047 as parameter to get 96 hours as the free fall time.
This means the max distance will be 52.047 * 6370 km , or about 86% of the Earth Moon distance.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
main( argc,argv )
int argc;char *argv[];
double acc_now,vel_now,acc_next,vel_next,step;
/* s= s0 + v0*t + 1/2*a*t^2 */
/* Initial distance: Number_of_radius*Radius , where Radius = Earth's Radius*/
double Number_of_radius,Time_interval,Radius,time_elapsed,total_distance;
double g;
if(argc != 2){
fprintf(stderr,"\n\nUse: %s InitialDistance\n", argv[0]);
fprintf(stderr,"\nEval free fall time given the initial height(in Earth's Radius units)\n\n");
exit(1);
g = 9.8 ; /* grav. accel = 9.8 m/s2 */
Radius = 6370000.0; /* Radius (Earth) - 6.37*10e6 m */
Number_of_radius = atof( argv[1] );
fprintf(stdout,"Distance (in Earth radius) = %f\n", Number_of_radius );
Number_of_radius += 1.0 ; /* Distance from the Earth's center */
vel_next = 0.0 ;
time_elapsed = 0.0 ;
total_distance = Number_of_radius*Radius ;
acc_next = g / (Number_of_radius*Number_of_radius) ;
vel_next = 0.0 ; /* in m/s */
Time_interval = 60. ; /* in seconds */
/* s = s0 - vt - 1/2 a t^2 */
while( total_distance > Radius ){
acc_now = acc_next;
vel_now = vel_next;
step = vel_now * Time_interval + .5 * acc_now * Time_interval * Time_interval ;
total_distance -= step;
vel_next = vel_now + acc_now * Time_interval ;
acc_next = g * (Radius / total_distance) * (Radius / total_distance) ;
time_elapsed += Time_interval ;
/* vel_now is the final speed */
time_elapsed -= Time_interval;
total_distance += step;
fprintf(stdout," Total time = %f seconds or %f hours.\n Final speed = %f m/s\n",
time_elapsed , time_elapsed/3600. , vel_now );
BTW, if g=9.8m/s^2 and R=6370km , the initial velocity would be about 11km/s.
Ok, I trust you did you programming right. I tried to solve the differential equation but came no furter than a distance dependent velocity and a maximum distance in terms of the initial velocity :cry:
A point to note is that this apparently high starting velocity (11km/s=99% of escape velocity) is not enough to cover even the Earth-Moon distance!
10K
  • · Replies 30 ·
  • · Replies 24 ·
