Schrodinger Equation: Kinetic Energy Impact?
HarryDaniels
I am sure you are all aware of the Schrodinger equation.
The Hamiltonian is included in this equations, which contains the Kinetic energy operator. When Schrodinger wrote thi he converted momentum to the unit imaginary number, the reduced Planck constant and the Delta operator.
My question is that this means that the Kinetic energy will be the same regardless of the characteristics of the quantum level particle. This does not make sense, surely the kinetic energy will affect the evolution of the state, due to the fact that it is energy.
Thanks to whoever clears this up for me.
-H
-H
Can you clarify your question?
The Hamiltonian is E = Ke + V where Ke is the kinetic component and V is the potential component.
Kinetic energy is related to the angular momentum and the momentum at any given point is the curvature of the particle at that point which changes with quantum state.
I am not sure if you are aware of the relation between the classical Hamilton function and the Hamilton operator.
In both classical and quantum mechanics we can write
H = E_\text{kin} + E_\text{pot}
The kinetic energy is expressed via the momentum as
E_\text{kin} = \frac{p^2}{2m}
In quantum mechanics you replace
p \to \hat{p} = -i\partial_x
and therefore you convert the Hamilton function in an operator acting on quantum states or wave functions.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
