Understanding Einstein's Theory of Relativity
  • Thread starter Thread starter ppr2010
    Confused E=mc2
ppr2010
I'm not really a physics genius or professor so forgive my lack of knowledge.
I was thinking about Einstein's theory of relativity earlier,then it just popped into my head doesn't that contradict The Law of Conservation of Charge?Ex:111grams of hydrogen = 10,000,000,000,000,000 Joules.but in order to achieve that amount it will have to be completely destroyed.
I thought matter and energy cannot be destroyed.Is it just converted and what i had read was misleading and inaccurate.
Mass and energy are not separately conserved in relativity. What is conserved is mass-energy, which is found by adding up all the mass and all the energy (after using E=mc^2 to convert them both into the same units). Conservation of charge is a separate issue. Charge is conserved. For example, when an electron and an antielectron annihilate one other, the total initial charge is zero, and the total final charge is also zero.
Yes the first time you are exposed to conservation law in school it is typically simplified.
I wondered how Wikipedia explained mass and energy and found this:
Mass also cannot be created or destroyed, and in all of its forms, has energy. According to the theory of relativity, mass and energy as commonly understood, are two names for the same thing, and neither one is changed or transformed into the other. Rather, neither one appears without the other. Rather than mass being changed into energy, the view of relativity is that rest mass has been changed to a more mobile form of mass, but remains mass. In this process, neither the amount of mass nor the amount of energy changes. Thus, if energy changes type and leaves a system, it simply takes its mass with it.
http://en.wikipedia.org/wiki/Mass-energy_equivalence#Conservation_of_mass_and_energy
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
