The terms function and map .
The terms "function" and "map" are often used interchangeably in mathematics, with "map" being more prevalent in advanced contexts. The discussion highlights that the use of the "mapsto" notation can obscure the codomain of a function, raising questions about the distinction between the two terms. While some sources suggest that "map" can refer to specific types of functions, such as morphisms in category theory, the general consensus is that they are synonymous. The definitions of functions provided differ only in terminology, indicating minimal practical distinction. Ultimately, the choice between "function" and "map" is largely a matter of author preference.
Fredrik
Staff Emeritus
Insights Author
The terms "function" and "map".
I have noticed that the term "map" is used more often than "function" when a map/function is defined using the "mapsto" arrow, as in "the map x\mapsto x^2 ". It has occurred to me that when a function is defined this way, it's usually not clear what the codomain is. So I'm wondering if the choice of the word "map" has something to do with this. Is it common to define "map" differently than "function"? (One way to do it would be to use the term "function" only for the first kind of function below, and "map" only for the second kind).
These are two standard definitions of "function".
Option 1:
Suppose that g\subset X\times Y and that f=(X,Y,g). f is said to be a function from X into Y if
(a) x\in X\Rightarrow \exists y\in Y\ (x,y)\in g
(b) (x,y)\in g\ \land\ (x,z)\in g \Rightarrow y=z.
Option 2:
Suppose that g\subset X\times Y and that f=(X,Y,g). g is said to be a function from X into Y if
Note that when the definitions are expressed this way, they only differ by one character.
Mathematics news on Phys.org
The difference between the two definitions is whether f or g is called the function? That doesn't seem to be a very productive difference to me.
An example of a "proper" way to denote a function using the mapsto arrowf:X\to Y, x\mapsto f(x) where f(x) is your formula of course. Usually your domain and codomain are suppressed because they're obvious from context; this would be no different from just saying "let f(x)=x2" and not saying what the domain/codomain are.
The word map itself means the same thing as function. It's probably used more as you read higher levels of mathematics, and the mapsto arrow is used more at the same time because the standard "f(x)=..." formula is no longer sufficient notation, so it's coincidence more than anything else that you notice the two together
That's my impression too. The only source I've seen actually claim that "map" and "function" can have different definitions is Wikipedia, and they didn't have a reference for that claim.
The terms "map" and "function" are often synonymous, but sometimes "map" could mean a morphism in some concrete category, such as a group homomorphism (a "map of groups") or a continuous function (a "map of topological spaces"). I know Hatcher explicitly defines a map to be a continuous function. The term "function" alone usually means a map of sets, ignoring any other structure.
That's how I see it, anyway. Which term is used is generally the preference of the author.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
