Determining Min & Max Slopes w/Varying STDEV
  • Thread starter Thread starter Salish99
    Data Max
To calculate the maximum and minimum slopes of a graph with data points that have individual standard deviations, one approach is to adjust the data points by adding and subtracting their standard deviations. This method allows for the determination of the extreme slopes based on the modified values. The validity of this analysis is questioned, prompting inquiries into alternative methods for calculating slopes considering the varying standard deviations. A suggestion of using "Weighted Least Squares" is proposed as a potential solution for this analysis. Overall, exploring different statistical techniques can enhance the accuracy of slope determination in the presence of unequal standard deviations.
Salish99
If I have a slope for which I do simple linear regression analysis, but each of the 6 datapoints of the slope have their individual (non-equal) standard deviations, how can I calculate the maximum and minimum slope of the graph?
One idea we too up was to increase the first half of the data points by the standard deviation, and decrease the other have by their standard deviations (and vice versa) in order to determine the maximum and minimum slopes from the resulting data points.
Is such an analysis valid? What else could I do to determine the maximum and minimum slopes based on the individual standard deviations?
If my explanation was unclear I have attached a document with simple made-up values for representation of the issue:
http://drop.io/stats20100/asset/minmax-gif"
This example data was created for simple commenting, the actual data is more complex.
Below the values used for this example:
x y σ, % σ y-σ y+σ MINsl MAXslope
1 1 10 0.1 0.9 1.1 1.1 0.9
2 2 20 0.4 1.6 2.4 2.4 1.6
3 3 10 0.3 2.7 3.3 3.3 2.7
4 4 10 0.4 3.6 4.4 3.6 4.4
5 5 20 1.0 4.0 6.0 4.0 6.0
6 6 10 0.6 5.4 6.6 5.4 6.6
LINEST
1 0 AVG
0.76 0.64 MIN
1.24 -0.64 MAX
Is "Weighted Least Squares" what you were looking for?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
