Permutations and transpositions contradiction
The discussion centers on the calculation of permutations and their representation as products of transpositions. Participants clarify that the parity of a permutation (even or odd) is determined by the number of transpositions used to express it, not by the number of digits involved. It is emphasized that if a permutation can be expressed with an odd number of transpositions, it cannot also be expressed with an even number, regardless of the number of objects. The correct representation of the given permutation is identified as (1,2)(4,5)(3), confirming its even nature. The conversation concludes by reinforcing that the parity of permutations is consistent across different representations.
morrowcosom
(2 1 3 5 4) Write the bottom number as a product of transpositions
41352 41325 41235 42135 42315 24315 24351 21354
(2 4) (2 5) (2 3) (2 1) (3 1) (4 2) (5 1) (4 1)
This an even number of transpositions but I ended up with the number. I read somewhere that it is impossible to calculate these products with an even number of transpositions if there is an odd number of digits or vice-versa. What is up with this, or what am I doing wrong? Is there a method to finding these products, or do you just plug in random numbers after the n-1 transpositions (2, 4) (2, 5) (2, 3) (2, 1)?
I don't follow what you did. Where did 41352 come from? Are you trying to apply the transpositions below each number to get the next? If you are, you don't seem to be doing it correctly. Could you explain more clearly what the problem is and your actual work?
Also, are you saying if you have an odd number of objects, there are no permutations of those objects that is the result of an even number of transpositions? That's obviously false because you can, say, start with 5 objects and apply two transpositions, right?
Whether or not a permutation is even or odd depends on its sign; 1 if even, -1 if odd, with
\mbox{sgn }\pi=(-1)^{n-c(\pi)}
where c(\pi) is the number of cycles in the disjoint cycle representation of \pi.
It doesn't only depend on number of digits.
So in this problem,
<br /> \left(\begin{array}{ccccc}<br /> 1 &amp; 2 &amp; 3 &amp; 4 &amp; 5 \\<br /> 2 &amp; 1 &amp; 3 &amp; 5 &amp; 4<br /> \end{array}\right) = (1,2)(4,5)(3)<br />
So it's disjoint cycle rep. has 3 cycles. Therefore n-c(\pi) will be even, so the permutation's sign will be 1.
where is the number of cycles in the disjoint cycle representation of .
So in this problem,
So it's disjoint cycle rep. has 3 cycles. Therefore will be even, so the permutation's sign will be 1.
I worked a transposition problem
(1 2 3 4 5)
(2 5 4 3 1) find the the product of the bottom sequence in transpositions.
My first step was to determine whether the number of transpositions was to be even or odd.
I presumed n=5, since this was the total numbers in the sequence. I then found disjointed cycles of (1 2 5) (3 4). I finally subtracted the number of disjointed cycles from n, to arrive at the conclusion that there should be an odd number of transpositions, since 3 is an odd number. But, I was able to solve the problem with an even number of transpositions. Is this supposed to be impossible, or is it just wrong?
25431
1) 15432 (2 1)
2) 15423 (2 3)
3) 15243 (2 4)
4) 12543 (2 5)
5) 21543 (2 1)
6) 25143 (1 5)
7) 25413 (1 4)
8) 25431 (1 3)
You're starting and ending at the same permutation, so of course you're going to find an even number of transpositions. You want to start with 12345 and find the number of transpositions needed to end at 25431.
\begin{pmatrix}1 &amp; 2 &amp; 3 &amp; 4 &amp; 5 \\ 2 &amp; 1 &amp; 3 &amp; 5 &amp; 4 \end{pmatrix}
I see immediately that 1 and 2 are swapped, that 3 remains in the same position and that 4 and 5 are swapped. This is the same as (12)(45).
" I read somewhere that it is impossible to calculate these products with an even number of transpositions if there is an odd number of digits"
No, that is not true. All transpositions on any number of digits are either "even" (require an even number of transpositions) or "odd" (require an odd number of transpositions)- and that, for any number of digits, exactly half of the transpositons are of each kind.
I suspect that you are incorrectly remembering that, while there may be many different ways of resolving a given permutation into a product of transpositions, they are either all odd or all even.
If one way of resolving a given permutation into a product of transpostions requires an odd number of transpositions, then there cannot be a way of resolving that same permutation into an even number of transpositions.
That has nothing to do with the number of digits.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
