Half-circle Parabolas: A Misconception?
  • Thread starter Thread starter CosmicVoyager
    Parabola
A half-circle is not a parabola, as circles have constant curvature while parabolas have non-constant curvature. The distinction lies in their definitions: a circle is the set of points equidistant from a center, while a parabola is defined by its relationship to a focus and a directrix. The intersection of a cone with a plane parallel to its axis creates a parabola, whereas a perpendicular plane forms a circle. Additionally, the eccentricity differentiates these conic sections, with parabolas having an eccentricity of 1 and circles having 0. Understanding these differences clarifies the misconception about their relationship.
CosmicVoyager
Greetings,
Is a half-circle a parabola? I am guessing yes because it is a conic section, the very bottom of the cone?
If yes, why aren't antenna dishes and telescope mirrors half-spheres? Wouldn't that be simpler?
Thanks
Mathematics news on Phys.org
No, it is not.
Circles have constant curvature at all points, parabolas have non-constant curvature.
As for your conic section argument, that would make hyperbolas into circles as well...
As a reminder:
A circle is the locus of points equidistant from a single point.
A parabola is the locus of points that have, individually, the same distance from a fixed point (the focus) and a fixed line (the directrix).
Since the definitions are not logically equivalent, nor are any part of the curves "the same", either.
No, a circle is not the same as a parabola.
A parabola is formed by the intersection of a cone and a plane parallel to the axis of the cone. A circle is formed when the intersecting plane is perpendicular to the axis of the cone.
This is a good question...most of the students may go baffle with this...
Actually, in conic sections, the main difference among parabaola, hyperbola and circle is their eccentricity. Eccentricity of parabola is 1 and that of the circle is 0.
For more info. about eccentricity.. check out this link:
http://en.wikipedia.org/wiki/Eccentricity_(mathematics )
Thanks for the answers. I understand now. I was thinking a parabola was a curve formed by a *any* plane intersecting the base and the side. Now I see the plane must be parallel to the side of the cone.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
