How Do Club Length and Mass Influence Golf Ball Distance?
  • Thread starter Thread starter becheras
    Golf Physics
The length and mass of a golf club influence ball distance primarily through their impact on club head speed and momentum. While the governing equations for ball distance do not directly include club length and mass, they affect the force and contact time during impact. A longer club can increase club head speed, enhancing momentum, while a heavier club head can increase force but may require more effort to swing. Other factors, such as the angle of the club face, ball hardness, and club surface characteristics, also significantly affect the distance the ball travels. Overall, optimizing club length and mass is essential for maximizing golf ball distance.
becheras
This is interesting...
How will the length and the mass of a golf club affect how far the ball will travel? What are the governing equations?
Hi there,
If you are trying to explain the distance travel by a golf ball only from the length and the mass of the golf club, you will have huge difference between your calculations and reality.
There are many other parameters that come into play: the angle of the club's face on the ball, the hardness of the club's surface, the dimples in the ball, the pattern of the dimples in the ball, the hardness of the ball, the whip effect of the shaft, ...
Now, I don't know the equations that are governing this movement by heart. I would say that you will need to look into many different fields of classical mechanics, like fluid dynamic for the movement of the ball in the air.
Cheers
The ball gets its momentum from the impact of the club head. The governing equation there is: p = Ft or, more precisely:
p = \int_{t_0}^{t_f} Fdt
where F is the force being applied by the club to the ball, and t (tf - t0) is the time during which they are in contact and p is the momentum of the ball that results (ball mass x velocity).
What you want to do is maximize the ball momentum.
Notice that neither the mass of the club head or the length appear in this equation. However, F and t will depend on the mass and speed (momentum) of the club head. The length of the club will affect the speed of the club head. Assuming the golfer is limited in the angular speed that he can rotate the club, a longer club will give faster club head speed. For a given club speed, a greater club head mass will tend to increase the force and the time over which the force is in contact with the ball. However, the greater mass will also require more effort by the golfer to accelerate to the desired speed, so it is a bit of a trade off.
AM
though it appears that mass and length do not make an appreciable effect
it does as explained by AM
mass will play a huge role as in momentum...
From rotational kinematics the linear speed of the club at impact is , v = wr
with w = angular speed = delta theta/delta t
So with r , the radius being roughly equal to the club length + arm length then v is
proportional to club length.
With m1 = club mass
u1 = club vel
m2= mass ball
v2= vel ball
then the velocity of ball after impact is
v2 =(2m1/m1 +m2) u1
The range of the ball = x =vo cos theta ) t
at any time t
At any time t that is < or = 2Vo sin theta/g
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
