Electrodynamics of point particle at relativistic velocities
For an extensive treatment of the electromagnetic field and energy of a point particle at relativistic velocities, chapter 15 of Franklin's "Classical Electromagnetism" is recommended, along with chapter 12 of Griffiths' "Introduction to Electrodynamics," which covers electrodynamics and special relativity. Wolfgang Rindler's "Introduction to Special Relativity" also includes a significant section on electromagnetism, though it focuses more on special relativity. The discussion highlights the availability of resources for understanding how fields transform under Lorentz transformations, with suggestions for both straightforward and more complex scenarios. Overall, there are multiple texts available that address various aspects of electrodynamics in the context of relativistic motion.
sanko
do you know any text or reference with extensive treatment on electromagnetic field ,potential & electromagnetic energy of point particle moving straight at relativistic velocities?
Try chapter 15 of Franklin's "Classical Electromagnetism".
Chapter 12 in the common 'Introduction to Electrodynamics' by David J. Griffiths is about electrodynamics and special relativity. I saw an example in the book about a moving point charge so that seems promising.
I had a book in a course once written by Wolfgang Rindler called 'Introduction to Special Relativity' which had a quite long section about electromagnetism and special relativity, but this book was more leaned towards special relativity than electrodynamics (as you can guess by the title).
How much of special relativity theory do you want? And what is it more specific that you're looking for? How the fields of a point charge transform under the Lorentz transformation? Cause that shouldn't be so hard to find, I guess there is a lot on Wikipedia for example.
For straight, no acceleration then I think that Griffiths may have that (I don't have it on hand to check though). If you want a detailed analysis for more abstract situations (relativistic, accelerating) Jackson has a good treatment of the subject.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
