Problem: Cartesian tensor to Spherical Tensor
gaffareee
Dear Frnds,
my problem is very simple. please help me.
I have a dielectric tensor like:
epsilon_T=
|1 0 0|
|0 1 0| %% note that it is in cartesian co-ordinate system
|0 0 a|
now the potential equation of dipole should be as in spherical system
V=1/(4*pi*epsilon_T (?) *epsilon_0)*(qdcos(theta)/R)
now should i change the epsilon_T value cartesian to spherical system ?
or how i can write down the code ?
should it be V_xx, V_yy and V_zz?
please hurry.
This equation doesn't make much sense. On the LHS you have a scalar, while on the RHS you seem to have an uncontracted tensor in the denominator.
I believe that you should have an expression for the potential (electric or energy, it doesn't matter) that is proportional to
\sum_{ij} (\epsilon_T)_{ij} E_i r_j.
As a scalar, this quantity can be evaluated in Cartesian coordinates and then written in terms of spherical coordinates, which would avoid having to convert vectors to spherical coordinates.
You haven't said what type tensor it is.
First write down the D field. For example, for a single point charge the D field is
\vec{D} = q/(4\pi r^2) \hat{r}
Then use the relationship \vec{D} = \epsilon \vec{E} to get the E field (you have to invert your dielectric tensor).
Then perform the integral to calculate the potential from the E field. The potential will still be a scalar but I think you will find that instead of 1/r you will have something like 1/sqrt(x^2+y^2+(az)^2). But you have to check.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
