Fortran What is the Syntax for Reading a Dataset in Fortran 90?
  • Thread starter Thread starter aLostProgramm
    Fortran
The discussion centers on a programmer transitioning from C/C++ to Fortran 90, facing challenges with syntax while attempting to read a dataset into a 1-D array. The user shares their initial code, which attempts to read a 5x4 dataset but results in incorrect output, displaying only the last row of data and many zeros. The main issue identified is the mismatch between the format specifier used in the READ statement and the variable being populated. The suggested solution is to simplify the READ statement to accommodate the data format, using "READ (1, *) X(I)" or employing an implied DO loop to read all values at once. This approach is recommended to ensure proper data handling and output.
aLostProgramm
I feel somewhat embarassed to ask for help concerning this. I am a C/C++ programmer, but I am currently learning Fortran 90 on the fly and in a hurry. I am going to have to read in a 32x25600 dataset into a 1-d array (I know, not especially efficicent). I decided to start with a more simplistic 5x4 dataset into a 1-d array, and would build from there. However, the unique syntax of Frotran 90 is confusing me. Below is my source code:
program test
IMPLICIT NONE
INTEGER I,var
CHARACTER*10 output
INTEGER, PARAMETER :: N=20
INTEGER, DIMENSION(N) :: X
OPEN (1,FILE="fake.dat",STATUS="OLD")
DO I=1,N
READ(1,"(5I3)",end=10) X(I)
END DO
10 do I=1,N
print *, X(I)
end do
END PROGRAM test
This is my dataset. The data is separated with a space in each row.
21 23 40 41 78
53 10 79 25 36
42 28 17 30 99
11 22 33 44 55
And this is my output:
44
55
I promise that I am not a student trying to get homework help. I am currently sitting in my cubicle trying to resist the temptation of punching my monitor out of frustration. Thanks in advance for the help.
Technology news on Phys.org
program test
IMPLICIT NONE
INTEGER I,var
CHARACTER*10 output
DO I=1,N
END DO
10 do I=1,N
print *, X(I)
end do
END PROGRAM test
21 23 40 41 78
53 10 79 25 36
42 28 17 30 99
11 22 33 44 55
44
55
Welcome to Physics Forums!
Your format specifier for the read doesn't agree with the variable you're using. The format expression, 5I3, indicates that you are reading 5 integer values. The variable X(I) can hold only one integer value.
Try this:
READ (1, *) X(I)
On a side note, you are printing the values out one-by-one, but attempting to read them in five at a time.
Mark44 said:
Your format specifier for the read doesn't agree with the variable you're using. The format expression, 5I3, indicates that you are reading 5 integer values. The variable X(I) can hold only one.
Try this:
READ (1, *) X(I)
You could also use an implied DO loop with the READ statement. The following code works with my compiler.
Code:
      IMPLICIT NONE
      INTEGER I,var
      CHARACTER*10 output
      READ(1,*) (X(I),I=1,N)
      DO I=1,N
            print *, X(I)
      END DO
      END
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
