Very simple C program ( running total)
  • Thread starter Thread starter liquidicy
    Program Running
The discussion revolves around a simple C program that calculates a running total based on user input. The original attempt incorrectly increments the variable 'amount' without reading user input, leading to a misunderstanding of the assignment requirements. The correct approach involves initializing 'total' to 0 and using 'scanf' to read three values into 'amount', adding each to 'total' sequentially. The feedback emphasizes the need for proper input handling and code formatting for clarity. Ultimately, the solution requires reading user input to achieve the desired functionality.
liquidicy
Very simple C program ( running total) [solved]
Question is:
Given that two int variables, total and amount , have been declared, write a sequence of statements that:
initializes total to 0
reads three values into amount , one at a time.
After each value is read into amount , it is added to the value in total (that is, total is incremented by the value in amount ).
My answer is this:
total = 0;
amount = 0;
do{
++amount;
total += amount;
}while (amount < 3);
Their response is:
Remarks:
⇒ Did you read in all three values?
Remarks:
⇒ At Execution
What did I do wrong?
Apparently I was just supposed to copy paste it three times with scanf("%i",&amount) instead of amount++
liquidicy said:
Question is:
My answer is this:
total = 0;
amount = 0;
do{
++amount;
total += amount;
Their response is:
Remarks:
Remarks:
⇒ At Execution
It's a good idea to put [ code] and [ /code] tags (without leading spaces) around your code. I've done it below, and indented your code to make it more readable.
Code:
total = 0;
amount = 0;
do
   ++amount;
   total  +=  amount;
} while (amount < 3);
In answer to the questions above, no, you didn't read in any of the three values. The values should have been entered at program run time.
Yes, you should use some input function, such as scanf, to do input.
