Solving Quadratic Equation: (a+b+c)^2
To solve for (a+b+c)^2 given the roots of the quadratic equation ax^2 + bx + c = 0 as p/(p+1) and (p-1)/p, one must first understand the implications of these roots. The sum and product of the roots can be used to derive values for a, b, and c based on Vieta's formulas. By substituting these values into the expression (a+b+c)^2, the solution can be calculated. The discussion emphasizes the importance of understanding polynomial roots in solving quadratic equations. Ultimately, the value of (a+b+c)^2 can be determined through careful analysis of the given roots.
nirajnishad
if roots of the equation ax^2+bx+c=0 be the form of p/(p+1) and (p-1)/p,the the value of (a+b+c)^2 is?
Think about what a "root" of a polynomial means and from there use the roots that you are given to deduce what you need.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
