Can Intense Laser Pumping Induce Lasing in a Two-Level System?
  • Thread starter Thread starter SSJVegetto
    population Thermal
The discussion revolves around the possibility of achieving lasing in a two-level system with a 10,000 cm-1 energy separation. The thermal population in the upper level is calculated using the Boltzmann distribution, yielding a ratio of N2/N1 = 0.61, indicating that the upper level population is not significantly populated at room temperature. Intense laser pumping can increase the upper level population, but it does not achieve population inversion, as N2/N1 remains less than 1. Consequently, lasing cannot occur in this two-level system; a three or four-level system is necessary for effective lasing due to faster decay rates from the upper laser level. The conversation emphasizes the importance of understanding energy differences and temperature effects in laser physics.
SSJVegetto
Assume a two-energy-level system with energetic separation between the two levels of 10000 cm-1 (as you can easily see, λ = 1 μm equals 1/λ = 10000 cm-1, and E ∝ 1/λ, i.e. the unit [cm-1] defines an energy).
a) What is the thermal population in the upper level?
b) If you pump the system with a very intense laser, how much will the
population of the upper level increase? Explain the result!
c) Under these conditions, can you achieve lasing? Explain the answer!
k\ =\ 1.3806503(24)\ \times\ 10^{-23}\ J\ K^{-1}
h\ =\ 6.62606876(52)\ \times\ 10^{-34}\ J\ s
\frac{N_{2}}{N_{1}}=\frac{g_{2}}{g_{1}}.e^{-(E_{2}-E_{1})/kT}
a. I'm assuming the degeneracy can be taken to be 1 for both? And now i use the equation given above to solve this problem and i get \frac{N_{2}}{N_{1}}=0.61 where i used for the energy difference E_{2}-E_{1}=\Delta E=\frac{hc}{\Delta\lambda}. Where i used \Delta\lambda=10000 cm^{-1} I am wondering if i got the energy right.
b. I really need some help with this one i just don't know how to answer this one. c. I don't know how to answer this i think when you can achieve population inversion the laser should be able to start lasing. But whether to tell if it can achieve that yes or no i don't know how to answer that and would appreciate some help.
Bob
Welcome to Physics Forums :smile:
Yes, it's strictly a two-state system, one upper state and one lower state.
Uh, not quite. Note that
ΔE = hc/λ, and it's 1/λ (not "Δλ") = 10000 cm-1, or λ=1 μm​
Also, what are you using for the temperature?
A very intense laser has the same effect as making the temperature very high.
Bob
Look at the equation for N2/N1, and imagine that T is very large. Will that make N2/N1 greater than 1, i.e. N2>N1?
Redbelly98 said:
Welcome to Physics Forums :smile:Yes, it's strictly a two-state system, one upper state and one lower state.
Ok and when do i know i have to use degeneracy? When will we be talking about degenerate energy levels? And thank you! :D
I used a temperature of 300 K which is room temperature i assume? Also what you are saying i don't really get? The energy difference between two states is equal to the wavelength of the photon that is radiated when going from the upper level to the lower level?
What is called very hot? What temperature do i use to determine how much of the upper level population is increased?
I do see that it never reaches N2/N1 = 1 and thus population inversion is not achieved and the absorption process remains dominant? So lasing is not possible. But how do i calculate how much of the upper level population is increased?
Ok by trying to look at the equation more qualitatively i see that this only becomes 1 for an infinite temperature where e^{0}=1. Thus lasing will not be possible when pumping this.
But when does it start lasing using this equation i mean there is never a system that reaches population inversion? Is it therefore that we need a three or four level system with a fast decaying upper level to the upper laser level?
You're welcome.
Use degeneracy when there is some information in the problem statement that indicates you should do so. When that happens is up to your professor.
Yes.
No, the energy difference is not equal to the wavelength! Use the E=hc/λ formula instead, with λ=1 micrometer = 10-6 m. (Your answer of N2/N1=0.61 is incorrect.)
You haven't said what energy you got, so I can't answer that.
Correct.
It does strike me as an odd question to ask. Perhaps an answer like "the population increases to almost _____", or something along those lines, will be sufficient.
Correct.
Yes, that's right.
Thank you for your answers! :D It helps me a lot!
I'm trying to calculate the value now but i don't seem to quite get it. You say i need to calculate it using E = hc/lambda right? That should be equal to the energy difference then right or how should i see this? I said previously that the energy difference is equal to the wavelength, I'm sorry for that for using sloppy words, i meant that the energy difference thus is a function of the wavelength and thus E = hc/lambda. If you ask me you now are assuming that the first energy level the lower population level has an energy equal to zero?
i use:
c = 3.108
h = 6.62606896.10-34
kb = 1.3806503.10-23
T = 300
\lambda = 1 \mu m
Now if i use these and fill these in in this equation:
\frac{N_{2}}{N_{1}}=e^{-\frac{hc}{\lambda}.\frac{1}{k_{b}.T}}
i get something like:
1.436.10-21
Is this correct?
1.436.10-21
Is this correct?
Looks good!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
