Solving the Schrodinger equation
spaghetti3451
This extract is from my college notes.
"Because of the inherent difficulty of obtaining even grossly approximate solutions of the complete Schrodinger equation, one typically focuses on reduced formulations that are believed to capture the essential features of the problem of interest. This has resulted in a number of parallel strands in the study of the electronic properties of solids and is, in large part, responsible for the richness of the subject as a whole. Experiments are constantly discovering new phenomena that either must be accommodated within the existing theoretical framework, or provide the basis for expanding this framework by introducing new fundamental concepts. Theory, in turn, makes predictions that challenge existing concepts and which must be tested by experiments."
inherent: Why has this word been used?
complete: Wat are the incomplete and the complete versions?
reduced formulations: Reduced? How?
This has resulted in a number of parallel strands in the study of the electronic properties of solids and is, in large part, responsible for the richness of the subject as a whole.:
I don't understand.
for expanding this framework by introducing new fundamental concepts: And why should the new fundamntal concepts fit into (be consistent with) the old theroetical framework?
Theory makes predictions that challenge existing concepts: How can a self-consistent theory make predictions that challenge the theory?
Finally, I don't see any connection between the first two and the last two sentences.
Anyone that helps I thank.
The complete Schrödinger equation for a system of merely two particles, in Cartesian coordinates, is
- \frac{\hbar^2}{2m_1}<br /> \left( {\frac{\partial^2 \Psi}{\partial x_1^2} + \frac{\partial^2 \Psi}{\partial y_1^2} + \frac{\partial^2 \Psi}{\partial z_1^2} \right) <br /> - \frac{\hbar^2}{2m_2}<br /> \left( {\frac{\partial^2 \Psi}{\partial x_2^2} + \frac{\partial^2 \Psi}{\partial y_2^2} + \frac{\partial^2 \Psi}{\partial z_2^2} \right)<br /> + V(x_1, y_1, z_1, x_2, y_2, z_2, t) \Psi = -i \hbar \frac{\partial \Psi}{\partial t}
where
\Psi = \Psi(x_1, y_1, z_1, x_2, y_2, z_2, t)
For systems with more particles, extend the equation correspondingly with more variables and terms. The key is that psi is a function of 3N+1 variables, where N is the number of particles in the system. To make any headway in solving this, you need to make simplifying assumptions that reduce the number of variables that you have to deal with.
failexam, I agree. Whoever wrote that passage must be getting paid by the word.
This is probably oversimplifying what you asked, but I think part of the problem is that there are not a lot of exactly solvable problems in Quantum Mechanics. In other words, we don't know how to solve the equations describing the physics, without resorting to approximate methods.
In most QM texts you solve unrealistic problems like the particle in the box, that are solvable. Then you might do the free particle (which in purest terms is also unrealistic) and the hydrogen atom. But, very quickly you go into time-dependent and time-independent perturbation theory, which are "approximation schemes".
I think the trick is self-consistent within its domain of validity.
GR is a good example. It, more or less, predicts singularities. In other words, it predicts a phenomenon it offers no explanation for.
This happens because it is going outside the domain where the theory is valid.
A self-consistent theory can make its boundaries of validity very evident in this way.
Thnaks for helping.
Why should he be getting paid by the word?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
