Preparing Atoms in Hyperfine State F=2: Optically Pumping?
Niles
Hi guys
As far as I have understood the technique of optical puming (OP), then if we look at the hyperfine state F=2 (for example), then OP can be used to prepare the atoms in the state F=2, mF=2, but not any other (i.e., lower) mF. Is there no technique for preparing atoms in a state with a lower mF?
Niles.
Well, you can get mF=-2 by using the opposite circular polarization of the light you are pumping with. To get the inbetween states you need the atomic lines and your laser lines to be very narrow to select precisely the transitions you want. Some low temp atomic gas groups use multiple lasers tuned to just the right transitions to predominantly take the atoms along a specific path of transitions, so this in principle would be possible (however they aren't trying to get to the mF inbetween states, they are just working with much more complicated atoms).
Thanks!
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
