Titration of unknown acid in lab, how to determine molar mass?
The discussion centers on determining the molar mass of an unknown acid through titration with NaOH. The user initially calculated the concentration of the acid solution using the equation C1V1=C2V2, but faced discrepancies in the resulting molar mass. Clarifications were made regarding the volume used in calculations, specifically that the titration only involves the 25 ml of acid, not the total volume after adding NaOH. The confusion arose from interpreting the final volume of the solution, as the user believed it should include both the acid and NaOH volumes. Ultimately, it was emphasized that the concentration calculations should focus solely on the acid solution's volume for accurate results.
redioactif
Hi,
It is in my chemistry lab course. I had 0.1g of an unknown solid that I diluted in 100ml of distilled water. Then, I took 25ml and titrated it with NaOH (Concentration = 0.0189M). To reach equivalent point (the point where concentration of NaOH is equal to the concentration of my unknown IN THE SOLUTION), it took 7.5ml of NaOH.
C1V1=C2V2
M=n/V , where n is number of moles, and V is volume of solution in liter.
Basically, I did C1V1=C2V2.
C1= 0.0189M V1=7.5ml C2=? V2=32.5ml (25ml + 7.5ml)
I then get C2=0.00436.
When I solve of n (in M=n/V) and then do grams/moles to get molar mass, I get a molar mass that is impossible, or waay off... So I'm not sure anymore if I am approching this correctly...Is my V2 correct? How about the V I take for M=n/V, is it 0.100L (initial volume at which I diluted the solid).
Thanks in advance for any help.
PS: This is my first post on this forum, and it seems really a great forum!
redioactif said:
Hi,
C1V1=C2V2
I don't think your V2 value is right, as you are only titrating 25 ml at the start. Also don't forget that the 25 ml is not the complete sample.
OK. If I put my V2 to 25ml, it gives an answer that makes a lot of sens.
However, I don't understand the logic behind it. I mean, the final volume of titration is NOT 25ml, but rather 25ml + 7.5 ml. The initial concnetration of NaOH that I have is for 7.5ml, but as we add that 7.5 to 25, it gets diluted, and the final volume would not be 25...
Can someone please help me understand this, or is my reasoning completley wrong?
The base (NaOH) is only in the 7.5 ml sample, isn't it. There is no additional base in the sample of 25 ml that you made up to titrate against this.
No there isn't. I had 25ml of acid only.
I added 7.5ml to reach equivalence point in the titration.
Apparently, my V2 has to be 25ml, but I don't understand why: shouldn't the final volume should include the added NaOH volume + the acid volume (25 + 7.5) ? I'm really confused!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
