How Do Moment Generating Functions Prove Distribution Stability Under Addition?
  • Thread starter Thread starter stukbv
    Functions Moment
Moment generating functions (MGFs) can demonstrate that the sum of two independent random variables (RVs) with the same distribution retains that distribution within the same family. The discussion highlights that while MGFs can uniquely determine a distribution when they exist, two different distributions can share the same MGF, making characteristic functions a more reliable alternative. The process involves calculating the product of the MGFs for the two RVs and showing that the resulting MGF corresponds to a distribution in the same family, with updated parameters. This framework is illustrated using the gamma distribution, where the sum of two gamma-distributed RVs results in another gamma distribution with adjusted parameters. Ultimately, the conclusion emphasizes that the sum's MGF reflects the original distribution's characteristics, confirming stability under addition.
stukbv
Hi, when asked to show that the addition of 2 independent RV's with the same distribution is once again of the same distribution, eg showing in gaussian that if X has mean m and variance v and Y has mean n and variance w then if i want to show that X + Y has gaussian distribution with mean m+n and variance w+v I use the product of their m.g.fs which is fine , when i get the result of this product, what is a good way to basically say that this shows the stability under additivity and that the parameters are m+n and w+v ?
Thanks
I don't fully understand your question. However, if X and Y are independent (not necessarily normal), as long as the means and variances exist, they add as you described. You just need to wotk with the first and second moments, where independence is used to give E(XY) = E(X)E(Y) in the variance calculation.
The Gaussian assumption is used only to get the fact that the sum is also Gaussian.
What I mean is, I am asked to show that the sum of 2 independent random variables each with the same distribution has that distribution again, i do this using the product of the mgfs, but how do i phrase / conclude throughly in words how this proves that the sum of the variables has the same distribution as the original ones?
You don't mean that the sum of 2 random variables has "has that distribution again". You mean that the sum is in the same "family" of distributions as the random variables that were added. (Whether it is or not, will depend on how you define the "family". There is no requirement that a "family" of distributions be defined by parameters, although this is the usual way of doing it.)
I don't think that, in general, that you can prove such a result using an argument based on the product of moment generating functions. Two random variables with different probability distributions can have the same moment generating function. You would need to show that for the "family" of distributions in question, the product of the moment generating functions could only be the moment generating function of a distribution in that family.
Try using characteristic functions instead of moment generating functions.
Really? I saw once that the mgf unique determines the distribution, provided that all the moments exist. Maybe I recall it wrong, I'll search for the reference...
The statement in "Probability and measure" in Billingsley is
If P is a probability distribution on the real line having finite moments \alpha_kof all orders and if the power series
\sum_{k=0}^{+\infty}{\frac{\alpha_kx^k}{k!}}
has a positive radius of convergence, then P is the unique probability distribution with \alpha_k as it's moments.
In particular, the mgf determines the distribution uniquely. The only problem is that not every random variable has an mgf, that's why one uses the characteristic function.
micromass,
You are correct. I was confusing the question of the uniqueness of the moment generating function (when it exists) with the fact that two distributions can have the same moments and not be the same distribution ( in a case where the moment generating function does not converge).
Stephen Tashi said:
micromass,
This is one reason why characteristic function is preferred to moment generating function. It always exists.
I'll provide you with a framework using the gamma distribution.
X ~ is ~ Gamma(\alpha_1, \beta); Y ~ is~ Gamma(\alpha_2, \beta)
<br /> <br /> E[e^{t(X+Y)}] = E[e^{tX}]*E[e^{tY}] = (\frac{\beta}{\beta - t})^{\alpha_1} (\frac{\beta}{\beta - t})^{\alpha_2} = (\frac{\beta}{\beta - t})^{\alpha_1 + \alpha_2}<br /> <br />
This matches the MGF of a gamma random variable with new alpha:
\alpha &#039; = \alpha_1 + \alpha_2
Therefore X + Y ~ gamma(alpha1 + alpha2, beta). Basically just show that the resulting MGF is the same MGF as before with new parameters.
