Why can't we form an image with just one ray of light?
An image in geometrical optics is formed where multiple light rays converge, creating a point of intensity rather than a single ray producing a clear image. The intensity of light at the convergence point can enhance visibility, but an image cannot be defined solely by intensity; it requires the gathering of rays to form a discernible shape. When light rays from a source meet at a point, they create a clearer image, while rays that spread out lead to blurriness. The quality of the image is influenced by the number of rays converging at the same spot, as well as factors like diffraction and aberration. Thus, multiple rays are essential for forming a distinct image, as they contribute to the overall perception of light and shape.
ashishsinghal
In geometrical optics we consider that an image is formed at the point where two rays meet. But meeting of two rays will just create a change in intensity, that too will change according to phase difference.
Also if the intensity say doubles it will make the image better visible but we cannot say that an image is formed only there. I'm confused. Please help...
Science news on Phys.org
Due to the nature of wave-like motion, when to waves come together that are in phase with each other, the waves add up into a larger, more intense wave.
I'm a bit confused, what do you mean when you say that an image isn't only formed there; do you mean the reflection off an object where waves unite and bounce off?
I mean that the image is considered only at the points where waves add up. In that case the image will be intensified let say 4 times. But if we consider an image of intensity 4I we must also consider images at the points where intensity is lesser say I, 2I, etc.
Also how can we be so sure that the light waves are in phase.
Take the example of a concave mirror having mirror on only one part of the principal axis. Here we can easily see that the light rays are traveling different distances.
If you use a parabolic reflector, the distances along all rays to the focus is the same. That's one way of actually constructing a paraboloid. A spherical reflector is 'near enough' for many purposes (not the HST, however for instance)
Look at Fermat's Principle on Wiki.
Geometric optics is a high frequency approximation. So a rough approximation with geometric optics will ignore the phase of the light. This is because the phase varies so quickly over the length scales of our problems that it is assumed to be random. There are, however, other high frequency methods that do take into account the signal's phase. Geometric optics can take this into account too if you work with a more rigorous mathematical approach.
Intensity has nothing to do with it. The image of a point is the only place where the light from it gathers to a point. Anywhere else, and the light will be spread out. (i.e. blurry)
Why do we need multiple light rays from a point to gather its image. Why can't it be done with a single ray? In other words,
What happens when two rays (from same point) meet that make its image visible?
There are rays going in all directions from the source, whether or not we draw them on paper. Every ray that meets your eye contributes to what you see.
If all of those rays meet your eye at the same point, you see a point-like object.
If all those rays meet your eye in almost the same point, you see a blurry object.
If those rays meet your eyes everywhere, you just see light without any discernible shape.
We call the place where the first case happens the "image" because if our eye is there, we see something that actually looks like the source.
Every ray that passes through the ideal lens passes through the image. We draw two rays because that's enough information to find it.
Maybe an example with reflection would be easier to understand.
Suppose we have a lamp with a light-bulb.
If the lamp shines on a mirror and we look, we see a light-bulb because the light is hitting our eye in only one place coming from one direction.
If the lamp shines on a wall, we see an illuminated wall rather than a light-bulb, because the light is hitting our eye everywhere from all directions.
The more light that gets into your eye, the brighter the image is. Same for a camera. If you use a large aperture on your lens, you can get a picture in lower level light because more of those 'rays' get onto the sensor. You can use a pinhole and form a dim image of an object (effectively using only one ray from each point on the object).
The quality of the image depends on how many of the rays actually get to the same spot. (That's in terms of ray optics, which are affected by things like chromatic and spherical aberration). There is another issue, involving diffraction (the wave aspect), and that determines when a sharp edge appears as a sharp edge or a blur / fringes. In general, the wider the aperture, the less blurring is caused by diffraction but the more impairments are caused due to other defects. Big telescopes are big in order to collect more light but also to improve the acuity / resolving power. aamof, there is always an optimum aperture for a camera, where ray optics and diffraction impairments are least worst and it always seems to be about f8.
