Zero-point energy cancelled by its gravitational energy?
The discussion centers on the relationship between zero-point energy (ZPE) and gravitational energy, suggesting that ZPE at each point in space is canceled by its negative gravitational potential energy. This cancellation leads to the conclusion that as the length scale approaches zero, both energy and potential energy diverge, resulting in a balance. The conversation also speculates on the implications of this balance for dark energy, proposing that advanced gravitational waves may influence the inertia of matter in the universe. A recent paper by Maggiore is referenced, discussing the subdominant role of ZPE in dark energy, highlighting ongoing research challenges in theoretical physics. The need for a robust framework, such as quantum field theory in curved spacetime, is emphasized for further exploration of these concepts.
johne1618
Consider the uncertainty principle:
dp * dx = hbar
For photons we have the relation:
E = p c
Substituting into the above uncertainty principle:
dE = hbar c / dx (1)
As we look at a smaller and smaller piece of the zero-point field the (positive) energy diverges.
But that energy has a mass equivalent which therefore has a negative gravitational potential self-energy, dP.
dP = - G dM^2 / dx (2)
As dx -> 0 then dP -> -infinity as fast as dE -> infinity so they cancel each other out.
If we have:
dE = -dP = dM c^2
and substitute this relation into (1) and (2) we get a relation for the length scale dx:
dx = sqrt(G hbar / c^3)
This is the Planck length.
I would guess that space-time quantisation is equivalent to the zero-point energy at each point being canceled out by its negative gravitational potential energy.
Space news on Phys.org
Hrmm...I wish I knew more on this. Maybe someone else knows something about this? I didn't think that zero point energy had any gravitational field.
I assume you are making a case against ZPE as the source of dark energy.
Yes - I think the zero-point energy at each point in space is exactly canceled by its negative gravitational energy.
I speculate that the dark energy/negative pressure is caused by advanced gravitational waves which impinge on the accelerating matter in the Universe and lead to that matter having an inertia - a possible mechanism for Mach's principle.
This is actually a more technical question than the initial responses and question seem to assume. The appropriate framework for this question is quantum field theory in curved spacetime (or quantum theories for gravitation). There are others on the forum who are much more proficient and technically savvy than I am on this issue but an interesting paper was recently written by Maggiore which deals with this issue.
http://arxiv.org/abs/1004.1782
Basic conclusion is that the ZPF contribute a subdominant 'dark' contribution leaving the nature of the dominant contribution to dark energy a problem for current research trends in theoretical physics. This is a fairly technical paper and I probably need to really sit down and read it properly, consider his derivations etc (as opposed to just reading through it somewhat briefly) - I wonder if anyone else has seen this paper or has any strong feelings on it one way or the other? I'd be glad to hear any thoughts on the paper from people.
As for Johne1618's post above, your line of approach is along that of backreaction in cosmological models. Be aware that your model requires a mechanism that can generate such horizon scale gravitational waves whilst remaining a subdominant contribution to perturbations (e.g. tensor modes are suppressed relative to scalar perturbations) - there are constraints from the CMB, CMB Polarisation, formation of large scale structure, growth history of the Universe etc. You would need to provide more explicit technical details before I can really comment on the viability of such a proposal. Similar backreaction effects have been considered in research by the likes of Buchert, Coley, etc. See, for example,
http://arxiv.org/abs/1012.3084
Hope this is of some interest and help.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
