Measurement in quantum mechanics problem
jplcarpio
Hi all,
In our assignment, we were given this question:
[PLAIN]http://img685.imageshack.us/img685/4854/prob213.png
I know that for (a), the answer is the first energy eigenstate since the measured energy corresponds to it. I'm not sure about the situation in (b), though.
Does "leaving the system alone, allowing it to evolve in the harmonic oscillator potential" mean that it returns to its original state (as given in the equation in the problem?
Or does it mean that a new state is created, following those in the harmonic oscillator potential, but with only the first energy eigenstate remaining?
I vaguely know that the act of measuring itself causes the wavefunction to collapse to a certain measurement and state, but what does the act of leaving it alone do?
I've tried to search through our reference, Introduction to Quantum Mechanics by David Griffiths, and through the Internet but so far I haven't seen material that might help me understand.
Thank you! :)
Measurement collapses the wave function. What equation tells you how the wave function evolves in between measurements?
I guess that would be the equation of the initial state, as given in the problem, since it's in the harmonic oscillator potential into which the system was allowed to evolve back. Would the initial state always hold in between measurements if it is left alone?
I've read that successive measurements would result in the same energy and energy eigenstate as the first measurement. Is that the only case when the measurement causes the wave function to change into specific eigenstates?
Thank you very much :)
No, that's not correct. Try reading up on the Schrodinger equation.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
