How can I analyze soil samples for vanadium content using two different methods?
  • Thread starter Thread starter oxshannon
    Analytical Chem
The discussion focuses on analyzing soil samples for vanadium content using two methods and determining if the results are statistically similar. Participants suggest calculating the mean and standard deviation for both methods and recommend using a t-test to compare the sample means. The original poster expresses difficulty due to missing class and lacking statistical knowledge, seeking guidance on how to proceed. Helpful resources, including links to t-test explanations, are shared to assist in understanding the analysis. The conversation highlights the challenges of catching up in a course while managing health issues.
oxshannon
The following data were obtained for the analysis of soil for vanadium content in mg/g using two different methods. Do the two methods yield essentially the same results?
Method 1 Method 2
26.30 26.22
26.43 26.32
26.28 26.20
26.19 26.11
26.49 26.42
I'm thinking I find the mean and standard deviation of each, find spooled and from there I'm not sure. So I know those 2 formulas, but I;m not sure on any others..
Didn't attempt because I kind of need a push in the right direction, not someone to do out the problem..
FYI, I have moved your 2 recent statistics questions to "Precalculus Mathematics".
Looks like a t-test is needed here. There should be something in your textbook or class notes about comparing two sample means.
p.s. welcome to Physics Forums.
thank you!
i can't really find anything in my textbook, and the only reason I am unsure on how to do this is because i was really sick for the class so i didnt get to go, but I am still required to pass the assignment in, so I am legit lost :(
When you know the right search terms, Google gives a lot of hits:
http://www.google.com/#hl=en&sugexp...pw.r_cp.&fp=93057ccd64abdef9&biw=1280&bih=678
Or check this wikipedia page; scroll down to the section titled "Independent two-sample t-test":
http://en.wikipedia.org/wiki/Student's_t-test#Independent_one-sample_t-test
By the way, it's a good idea to ask a classmate if you could copy their class notes whenever you have to miss a class.
EDIT: out of curiosity, is this a statistics or a chemistry class (or something else)?
Thanks a lot!
It was the second day of classes (terrible time to come down with the flu), and I don't know anyone in the class, the professor just e-mailed me the assignment and still wants me to hand it in on time without notes. That's another story though.
It's an analytical chemistry class, so I guess the introduction is mainly statistics (which I never took, so I'm even more lost). It's a terrible situation really.
EDIT: That wikipedia link looks perfect for what I have to do.. thanks a lot! Also, any idea on the other question I posted? :-)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
