How to Interpret Wave Equations in Bras and Kets?
  • Thread starter Thread starter atomicpedals
    Wave
atomicpedals
My texts aren't exactly clear on how to handle equations of this sort:
|ψ>=c(1|1>+2|2>-3|3>)
How is one to interpret this? All I'm sure of is that |ψ> is ψ(x) and that c is the normalization constant (which would be solved for in the usual way). Any tips or pointers towards resources for further study are greatly appreciated!
It's a vector equation, like
\vec{x} = c(1\vec{v}_1+2\vec{v}_2-3\vec{v}_3)
\psi(x) is actually the amplitude \langle x \vert \psi \rangle. Consider
\vert \psi \rangle = \int dx\,\lvert x \rangle\langle x \rvert \vert \psi \rangle = \int dx\,\vert x \rangle \langle x \vert \psi \rangle = \int dx\, \psi(x) \vert x \rangleto see what \psi(x) means in a linear algebra sense.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
