Text formatting + writing a matrice
  • Thread starter Thread starter JamesGoh
The discussion centers on creating perfectly aligned matrices using text formatting tools. LaTeX is highlighted as a method for entering matrices, specifically using the code \begin{bmatrix} for brackets. An example matrix is provided to illustrate the correct syntax. Alternatives to this method exist, but LaTeX is noted as one of the simplest techniques. Proper formatting is essential for achieving the desired visual output in mathematical contexts.
JamesGoh
What button in the text formatting allows you to create perfectly aligned matrices ?
Do you mean like using "code" tags to get uniformly spaced text? Or do you mean creating matrices in LaTeX?
You can enter a matrix (there's no such word as matrice) using LaTeX like this:
[ tex ]\ begin{bmatrix}1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1 \ end{bmatrix}[ /tex ]
This LaTeX code (with the extra spaces removed from the tex tags and before begin and end) produces this matrix:
\begin{bmatrix}1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1 \end{bmatrix}
There are several other ways to do this, of which this technique is probably the simplest. If you want the matrix surround with parentheses instead of brackets, use pmatrix in both places.
