How to find the roots of polynomial of a 5.th order
  • Thread starter Thread starter johny2012
    Polynomial Roots
johny2012
I have a polynimal equation as this
- 0.00000000000049125*T^4 + 0.00000000021358333333333333333333333333333*T^3 + 0.00000290233125*T^2 - 0.032444109375*T + 19.891472013020833333333333333333
I insert those polynomial coeffictions to an line matris
a = [- 0.00000000000049125 0.00000000021358333333333333333333333333333 0.00000290233125 - 0.032444109375 19.891472013020833333333333333333]
a =
-0.0000 0.0000 0.0000 0.0324 19.8915
and call roots function with thi array
roots(a)
and get this values
ans =
1.0e+003 *
4.8369
-1.8781 + 3.0710i
-1.8781 - 3.0710i
-0.6460
I seen, there are real and complex roots. So, How can I find real value of T ??
Should I use a method like bisection ? If so how ?
a =
roots(a)
and get this values
ans =
1.0e+003 *
4.8369
-1.8781 + 3.0710i
-1.8781 - 3.0710i
-0.6460
First of all, your equation is not 5th "order" (proper term is degree), it's only 4th degree (also called a quartic equation).
There are at most 4 distinct roots to any quartic with rational coefficients (like you have). These roots can be found exactly with certain algebraic operations, but it's fairly tedious. You've apparently already run the equation through a solver and got those roots.
So you have two distinct real roots and two complex roots (the ones with 'i' in them), to give a total of 4 roots. If you only need the real roots, just use those (so T can be either of those values). Just ignore the complex roots unless you have a problem where you need to use those (and you have some means to interpret a complex solution).
Thanks for the valuable information.
I tried this online polynomail root solver and entered the polnomial coefficients,
and the these results.
Instead of 1.0e+003 *
4.8369
I get
4836.92716144589
and others are
x2:
-646.021532813122
x3:
-1878.065197692127 + 3071.020155085326i
x4:
-1878.065197692127 - 3071.020155085326i
. I get confused at this point, I can not fully understand "e" concept here, I know it means exponential but I do not know how can I calculate real value of a number which contains that "e" sign.
I mean, in this case
1.0e+003 *
4.8369
is equals to 4836.92716144589 ??
Which numebr should I accepts, can you also help me on this ?
4.8369
I get
4836.92716144589
and others are
x2:
-646.021532813122
x3:
x4:
. I get confused at this point, I can not fully understand "e" concept here, I know it means exponential but how can I calculate real value with that e sign.
I mean
1.0e+003 *
4.8369
1e3 means 1000 here. The '*' means times (multiply). The first solver was factoring out the 1000, so that the numbers appear smaller. You're meant to take 1000 times each number to get the actual solution.
The second solver just gave the solutions as is.
"x"e"y" also written as xEy or xEXPy (that's why some scientific calcs have that "EXP" key, which means the same thing) where x and y are numbers (generally x is a single digit number greater than or equal to 1 and less than 10 and y can be anything, positive or negative) means x TIMES 10^y.
So 2e4 = 20,000. and 3e-6 = 3/1,000,000.
It's a form of Scientific Notation: http://en.wikipedia.org/wiki/Scientific_notation
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
