Chain rule for implicit differentiation
Tuomo
I have derivative dx/dt = y(u(t)) * z(u(t)) + u(t)
Now, what is dx/du ? I know the chain rule should help, but I am stuck :-(
Maybe \frac{dx}{du}=\frac{dx}{dt} \cdot \frac{dt}{du}.
Thanks fluidistics.
Ok, so, what I get is:
\frac{dx}{du}=\frac{dx}{dt} \cdot \frac{dt}{du}=\left[y(u(t)) \cdot z(u(t)) + u(t)\right] \cdot \frac{dt}{du(t)}
Now, what the heck is this \frac{dt}{du(t)} ? Any idea how should I treat it?
Is it just a reciprocal of \frac{du(t)}{dt}? In other words, can I just divide the original function with the time derivative of u(t)?
\frac{dx}{du}=\frac{dx}{dt} \cdot \frac{dt}{du}=\left[y(u(t)) \cdot z(u(t)) + u(t)\right] \cdot \left[\frac{du(t)}{dt}\right]^{-1}
Thanks for help and comments! Its is almost... uhhhh... 15 years since I studied this stuff in university.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
