Need method for trilateration of 3 GPS satellites
To determine the intersection points from three GPS satellites using trilateration, the method involves solving a set of nonlinear equations based on the distances (pseudoranges) from the satellites. The user has identified that a nonlinear least squares approach is necessary due to measurement errors in the pseudoranges. They are seeking assistance with MATLAB, specifically on how to implement the LSQNONLIN function to minimize the error in their calculations. The equations provided outline the relationships between the receiver position and satellite positions, which need to be solved iteratively. Guidance on coding this process in MATLAB is requested to complete the project effectively.
tribaljunkie
Can someone please shed some light on the exact method for finding the two points at which the spheres created by the GPS signals from 3 different satellites intersect? I have been working on a uni project for 4 days now and still can't get this relatively simple part of my MATLAB code to work. I realize the 4th satellite is for a time error, but that's not part of my report, i just have the position of that to select the intersection point with the range closest to the pseudorange from the 4th satellite.
the data i have is 4 satellite positions and their corresponding pseudoranges.
if someone could give me the mathematical method, or if you're able even the MATLAB process required as I am a bit rusty with it.
any help much appreciated, cheers.
after a bit more research iv found i need to use the non linear least squares method in MATLAB, but still having trouble coding it.
if the ranges from the satellites were perfect i could use the simultaneous equations
0 = (ri_ia(1,1)-ri_is1(1,1))^2+(ri_ia(2,1)-ri_is1(2,1))^2+(ri_ia(3,1)-ri_is1(3,1))^2 - rho_1^2;
0 = (ri_ia(1,1)-ri_is2(1,1))^2+(ri_ia(2,1)-ri_is2(2,1))^2+(ri_ia(3,1)-ri_is2(3,1))^2 - rho_2^2;
0 = (ri_ia(1,1)-ri_is3(1,1))^2+(ri_ia(2,1)-ri_is3(2,1))^2+(ri_ia(3,1)-ri_is3(3,1))^2 - rho_3^2;
0 = (ri_ia(1,1)-ri_is4(1,1))^2+(ri_ia(2,1)-ri_is4(2,1))^2+(ri_ia(3,1)-ri_is4(3,1))^2 - rho_4^2;
where ri_ia is the receiver position (1x3 vector), ri_is is the satellite position (1x3 vector) and rho is the corresponding range from receiver to satellite (scalar). Also rho includes unavoidable errors.
as the measurements are not exact i must use the least squares approach minimising the error dri_ia.
dri_ia1 = (ri_ia(1,1)-ri_is1(1,1))^2+(ri_ia(2,1)-ri_is1(2,1))^2+(ri_ia(3,1)-ri_is1(3,1))^2 - rho_1^2;
dri_ia2 = (ri_ia(1,1)-ri_is2(1,1))^2+(ri_ia(2,1)-ri_is2(2,1))^2+(ri_ia(3,1)-ri_is2(3,1))^2 - rho_2^2;
dri_ia3 = (ri_ia(1,1)-ri_is3(1,1))^2+(ri_ia(2,1)-ri_is3(2,1))^2+(ri_ia(3,1)-ri_is3(3,1))^2 - rho_3^2;
dri_ia4 = (ri_ia(1,1)-ri_is4(1,1))^2+(ri_ia(2,1)-ri_is4(2,1))^2+(ri_ia(3,1)-ri_is4(3,1))^2 - rho_4^2;
thing is i have no idea how to get MATLAB to do this for me, could anyone lend a hand. i know the function is LSQNONLIN but i am not experienced enough with MATLAB to understand the help file and implement it.any help would be great, thanks.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
