I need a little help with differentials
  • Thread starter Thread starter James2
    Differentials
James2
Alright, I know my algebra, geometry, and plane trigonometry. I've been calculating derivatives for a while now, but I wish to get to a higher level of differentiation. Say, differential equations. Could somebody explain how to solve a differential equation?
Welcome to PF!
Hi James2! Welcome to PF! :smile:
Sorry, but you need to know integration before you can solve differential equations. :redface:
(basically, because you have to "undo" the equation, and "undoing" a derivative is integration)
here's some you can do:solve y' - cy = 0. If you have been differentiating much you know that e^ct works.So here is another similar one:
solve y'' - 3y' + 2y = 0.
to solve it just guess the solution to be e^ct, and differentiate to find c.
You will see that e^ct works if and only if c solves the polynomial equation
x^2 -3x + 2 = 0, i.e. if and only if c = 1,2.what about y'' + y' -2y = 0?
Hey James2 and welcome to the forums.
This question that is seemingly so simple, is actually not an easy one to answer.
The thing is that not all differential equations were created equal.
In some cases you can use some rather simple substitutions or calculus identities (like the chain rule) to get the answer and for others, you have to resort to things like integral transforms like the Laplace transform.
Even then with the mathematical machinery that we have, many differential equations like non-linear ones just can't be solved with the techniques we have at the moment and because of this we need to not only use computers, but we have to understand the theory that makes getting a solution actually work to begin with.
So keep the above in mind: in other words, we can't always solve a DE like we solve say a set of equations like x + 2y = 4 and x + 3y = 7 where we get x = blah and y = blah: it's not that easy when you start getting to the complicated kind of equations.
In terms of understanding differentiation though, once you understand all the basics like the chain rule, product rule, quotient rule and others including partial derivatives, then the rest is pretty much using these rules in a given context.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
