Jacobian matrix determinant vanishes
The discussion centers on the implications of a vanishing determinant in a Jacobian matrix during coordinate transformations. A zero determinant indicates that the transformation is not invertible, suggesting it may not be a good transformation. The transformation in question involves Euler angles applied to a solid cube's initial position. It is noted that the determinants of standard rotation matrices are always 1, implying a potential calculation error in the Jacobian. The conclusion emphasizes the importance of verifying calculations to ensure the validity of the transformation.
Demon117
What exactly does it mean when the determinant of a Jacobian matrix vanishes? Does that imply that the coordinate transformation is not a good one?
How do you know if you coordinate transformation is a good one or a bad one?
Let me explain further. This is the particular transformation I am looking at:
\left(<br /> \begin{array}{c}<br /> x(t) \\<br /> y(t) \\<br /> z(t)<br /> \end{array}<br /> \right)= R_{z}(\gamma) R_{x}(\beta) R_{z}(\alpha)\left(<br /> \begin{array}{c}<br /> x_o \\<br /> y_o \\<br /> z_o<br /> \end{array}<br /> \right),
here, the vector (x_{o},y_{o},z_{o}) is just the initial positions of small pieces of a solid cube, and the angles \alpha(t),\beta(t),\gamma(t) are the Euler angles (all functions of time).
When I expand this out, and form the Jacobian matrix, it's determinant vanishes.
Probably there is a mistake in your calculation. In the standard forms, the determinant of Rx , Ry and Rz all are 1.0 , for any angles. So is the determinant of their product.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
