Thanks again.Identification Algorithm for Parameter-Varying System?
The discussion centers on identifying parameters in a parameter-varying system using a model defined by differential and algebraic equations. The user has input and output measurements but faces challenges due to the complexity of the model, which involves 24 parameters derived from 8 expressions. Previous attempts with algorithms like least squares, gradient methods, and Newton-Raphson have been unsuccessful. The user seeks advice on effective identification algorithms suitable for this type of problem. Sharing the model is not possible due to restrictions, but insights on potential solutions are welcomed.
FaroukSchw
Hello everybody
I started recently working on an engineering problem that requires as a first step, the identification of the system.
I already have a model which is a set of differential and algerbraic equations. Unfortunatelly, the system is a parameter varying one, and the aime is to identify these parameters. Taking in consideration that i have input and output measurements, and about 20 parameter to identify.
Does anyone have an idea about an identification algorithm that can be used for such problem?
Regards.
It really doesn't make much sense to estimate the parameters of a time-varying system, unless you have the model for the time dependence of the parameters as well (periodicity, explicit functional form?) or you have some specific real-time application that I can't think off right now. Anyway, I'd really appreciate it if you'd share your models and tell us what you're trying to do
Hi elibj123
Thanks for taking time and responding to my thread.
In fact, i do have the expressions of the parameters, but since the model has 8 parameters, each parameter's expression contains three parameters, so 8*3=24 paameter to be identified.
The sensitivity of the model to the parameters varries from one parameter to an other.
I tried some algorithms such as different versions of the least squares, Gradient algo, Newton-Raphson, but they don't work!
Unfortunatelly, i can't share the model, because i don't have the right to, at least for the time beying.:frown:
I will be verry glad if you can provide some advices.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
