Uhh help with this proof then x is prime .
  • Thread starter Thread starter charmedbeauty
    Prime Proof
charmedbeauty
uhh! help with this proof """" then x is prime""".
For a positive integer x≥2.
"if x is not divisible by any positive integer n satisfying 2≤n≤√x then x is a prime number"
a) show that the above statement is true .
b) Is the statement still true if the condition on n is replaced by 2≤n<√x ??
Well firstly I really have problems with proofs in general, but
x≥4
so x can be [4,5,6,7,...∞)
so by definition of prime number x--> x/x and x/1
but I really don't know how to approach this
I know its true because n= [2,3,4,5...∞)
and so the only numbers not possibly divisible by n are primes, Since n can be any positive integer ≥2, and Since x≠1.
But how do I put it in mathematical terms??
HELP!
Try and prove the contrapositive. If x is NOT prime then there IS a positive integer satisfying 2≤n≤√x that divides x.
An integer x>1 is composite if there exists some number 1<n<x that divides n. The integer x is prime if not such number n exists. What this is this theorem is telling you is that you don't have to look at all integers between 2 and x-1 (inclusive). You only need to look at those between 2 and √x (inclusive).
Hint: Suppose n is an integer that divides x. In other words, m=x/n is an integer. What can you say about m if √xn<x?
Well mn=x so x is not a prime if this condition is satisfied.
and m can be any positive integer >1 since m=x/n which is greater than 1 since n<x, and n,x are positive integers.
But I don't really understand when exactly this condition satisfies, namely, mn=x, Since to me mn could be less than, equal, or greater than x.
Since m>1 and n<x. There are values of x,m,n that satisfy all three conditions ie, <,=,>.
On second thoughts m>x so since n≥2 then mn>x.
So I think this tells me that if x does not divide some n≥2 then x is not prime?? Although I think for this to be true I need the eqn to be mn=x? I am confused.
Surely this is not what you meant to say? Any x, prime or not, divides 2x, for example.
It is true that if x is not divisible by some n\ge 2 (except x itself) then x is prime.
If x= mn and m&gt;\sqrt{x}, what can you say about n?
As for "b) Is the statement still true if the condition on n is replaced by 2≤n<√x ??",
consider x= 9.
consider x= 9.
if x=mn and m>√x
then all I can say from this statement is that mn is > √x. And that n is <√x, Since mn=x. I'm still really lost?
If x is composite, we can factor it as x=mn we have two possibilities
1) m< √x
2) n< √x
In both cases, we see that if x is composite, it is divisible by a number which is no larger than √x, which is exactly what you wanted to prove (after you change some strict inequalities to weak inequalities)
1) m< √x
2) n< √x
Ok thanks Office Shredder and others that helped...
so does this proof look correct now.
given ---> 2≤n≤√x and x≥2
So n≥2 from above inequality.
Suppose x is not prime, then, by definition of a prime
m = x/n for some integers m and x,n both≥2
hence, x=mn
Now either n< √x or m<√x or m=√x iff n=√x
In either case x/m or x/n
But if x is prime, by definition, x cannot divide m or n where m,n≥2
Hence m is prime iff x does not divide n where 2≤n≤√x
proof finished.
and for part b)
let x=9
therefore, 2≤n<3
Now x is prime iff x does not divide n for some integer n satisfying above inequality.
but 9 does not divide 2 and when x =9, n must =2 (satisfying the above inequality).
Hence x is prime. Contradiction. 9 is not prime. Therefore above inequality does not hold.
charmedbeauty said:
and for part b)
let x=9
therefore, 2≤n<3
I have no idea what you are trying to do. All you need to note is that 9 is not prime and \sqrt{9}=3. "2\le x&lt; \sqrt{9}= 3" is true only for x= 2 and 2 does not divide 9. End of counter example.
Ok thanks, undestood!
