Examples of ordered topology on R x R
  • Thread starter Thread starter Pippi
    Topology
Pippi
I am trying to understand the difference between ordered topology and subspace topology. For one, how do I write down ordered topology of the form {1} x (1, 2] ? How do I write down a basis for {1,2} x Z_+ ?
What order are you planning to put on these spaces?? (specifically the second one)
I want to put dictionary order on them, so (1, 2) is less than (2, 2) and also less than (1,3). I don't know other orders can be put on them (maybe a metric?) than dictionary order.
So, the order topology is by definition generated by intervals. That is
\{x~\vert~a<x<b\}
Can you give a description of the intervals in your two spaces?
For the space {1} x (1, 2], the intervals are half open intervals {x | (1, 1] < (1, x] < (1, 2]}. I can also define open intervals {x | (1, 1) < (1, x) < (1, 2)} and a half open interval about {1, (1, 2]}. Both are valid topology.
The space {1,2} x Z_+ contains the set {{1, 1} {1, 2} ... {2, 1}, {2, 2} ... }. Because I can define the basis {x | (x - 1, x + 1), x in Z_+} for space Z_+, the basis are {{1, (x - 1, x+1), {2, (x - 1, x +1)}}. The basis for x = 1 are {1, [1, 2)} and {2, [1, 2)}.
I can't find errors but this is suggesting that I can find many different order topology on a set? Infinitely many? :/.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
