Fortran Why is my Gfortran Code Not Compiling?
  • Thread starter Thread starter RissaR
    Error Gfortran
The discussion focuses on a Fortran programming issue where the user is trying to compile a code that includes subroutines for linear interpolation and mean wind calculation. The user encounters multiple compilation errors, primarily due to incorrect placement of subroutines within the main program and conflicting attributes for dummy arguments. Suggestions include moving the subroutines outside of the main program block and ensuring the main program performs meaningful operations, such as calling these subroutines. The user reports progress in resolving other errors but identifies this structural issue as the most significant hurdle.
RissaR
I'm new to programming in Fortran, but have programmed for quite a while in C, Matlab, and Python.
This is my code. It's incomplete at the moment (the subroutines are unreferenced), though it should still compile, but won't.
Code:
PROGRAM bunkers
      IMPLICIT NONE
      SUBROUTINE lininterp(ulist,vlist,hlist,targetlvl,u,v)
            IMPLICIT NONE
            !Dummy argument declarations
            REAL, INTENT(IN) :: ulist,vlist,hlist,targetlvl
            REAL, INTENT(OUT) :: u,v
            !Local variable declaration
            REAL :: spacing
            spacing = hlist(2) - hlist(1)
            DO i=1,SIZE(hlist)
                  IF (targetlvl>hlist(i) .and. targetlvl < hlist(i+1)):
                        u=(ulist(i+1)-ulist(i))/spacing*(targetlvl-hlist(i))+ulist(i)
                        v=(vlist(i+1)-vlist(i))/spacing*(targetlvl-hlist(i))+vlist(i)
                  END IF
            END DO
            RETURN
      END SUBROUTINE lininterp
      SUBROUTINE meanwind(ulist,vlist,hlist,blayer,tlayer,meanwind)
            IMPLICIT NONE
            REAL, INTENT(IN) :: ulist,vlist,hlist,blayer,tlayer
            REAL, INTENT(OUT) :: meanwind
            REAL :: vmod, i, j, umodmean, vmodmean
            REAL, ALLOCATABLE, DIMENSION(:) :: tailvect,headvect
            REAL, DIMENSION(2) ::   vector,modheadvect,vect,modmean, meanwind
            REAL, DIMENSION (2,2) :: rotation,counter
            !Find head and tail wind vectors
            DO i=1,SIZE(hlist)
                  IF (hlist(i) .eq. blayer) THEN
                        ALLOCATE(tailvect(2))
                        tailvect = (/ ulist(i),vlist(i) /)
                  ELSE IF (hlist(i) .eq. tlayer) THEN
                        ALLOCATE(headvect(2))
                        headvect = (/ ulist(i), vlist(i) /)
                  ELSE IF (hlist(i) >= tlayer) THEN
                        EXIT
                  ELSE
                        EXIT
                  END IF
            END DO
            IF (.not. allocated(tailvect))
                  CALL lininterp(ulist,vlist,hlist,blayer,u,v)
                  tailvect = (/ u,v /)
            END IF
            IF (.not. allocated(headvect))
                  CALL lininterp(ulist,vlist,hlist,tlayer,u,v)
                  headvect = (/ u,v /)
            END IF
            RETURN
      END SUBROUTINE meanwind
      STOP
END PROGRAM bunkers
Output:
Code:
Larissas-MacBook-Pro:Sounding_Codes Larissa$ gfortran -o idmethod idmethod.f90
idmethod.f90:4.6:
Error: Unclassifiable statement at (1)
idmethod.f90:5.25:
            IMPLICIT NONE
Error: Duplicate IMPLICIT NONE statement at (1)
idmethod.f90:14.27:
Error: PROCEDURE attribute conflicts with INTENT attribute in 'hlist' at (1)
idmethod.f90:16.37:
idmethod.f90:17.32:
Error: PROCEDURE attribute conflicts with INTENT attribute in 'ulist' at (1)
idmethod.f90:18.32:
Error: PROCEDURE attribute conflicts with INTENT attribute in 'vlist' at (1)
idmethod.f90:19.21:
                  END IF
Error: Expecting END DO statement at (1)
idmethod.f90:22.7:
Error: Expecting END PROGRAM statement at (1)
idmethod.f90:24.6:
idmethod.f90:25.25:
            IMPLICIT NONE
Error: Unexpected IMPLICIT NONE statement at (1)
idmethod.f90:28.37:
Error: Symbol 'ulist' at (1) already has basic type of REAL
idmethod.f90:29.41:
Error: Unexpected data declaration statement at (1)
idmethod.f90:32.50:
idmethod.f90:33.64:
idmethod.f90:34.77:
idmethod.f90:35.53:
idmethod.f90:39.27:
idmethod.f90:40.41:
Error: Syntax error in ALLOCATE statement at (1)
idmethod.f90:41.43:
idmethod.f90:42.32:
idmethod.f90:43.41:
idmethod.f90:44.43:
idmethod.f90:45.32:
idmethod.f90:47.22:
                  ELSE
Error: Unexpected ELSE statement at (1)
idmethod.f90:49.21:
                  END IF
Fatal Error: Error count reached limit of 25.
Any ideas?
Technology news on Phys.org
Don't put the subroutines inside the program section.
Also, you main program should actually do something useful, like call the subroutines.
Your code should look something like this:
Code:
PROGRAM bunkers
  ! declarations
  ! statements
END PROGRAM bunkers
SUBROUTINE lininterp( ... )
  ! declarations
  ! statements
SUBROUTINE meanwind( ... )
  ! declarations
  ! statements
Code:
PROGRAM bunkers
  ! declarations
  ! statements
END PROGRAM bunkers
  ! declarations
  ! statements
  ! declarations
  ! statements
I have successfully fixed most of the other errors, but this was the biggest problem I was running in to. Thanks so much! :)
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
