A nonlinear difference equation
asmani
Consider the equation
\frac{a_n-a_{n-1}}{1+a_na_{n-1}}=\frac{1}{2n^2}
I know one special solution is
a_n=\frac{n}{n+1}
But how to solve and find the general solution?
Thanks in advance.
hi asmani! :smile:
hint: trig substitution :wink:
Thank you tiny-tim. I don't think that works, since the the equation is actually coming from trigonometry!
Mathematica gives the following solution:
a_n=\frac{a_0+\left (1+a_0 \right )n}{1+\left ( 1-a_0 \right )n}
But I don't know how to derive this solution analytically.
P.S. The original problem was to show that:
\sum_{n=1}^{\infty}\tan^{-1}\left (\frac{1}{2n^2} \right )=\frac{\pi}{4}
asmani said:
Thank you tiny-tim. I don't think that works …
yes it does!
try it! :smile:
a_n=\tan\theta_n? Another hint please!
asmani said:
a_n=\tan\theta_n?
yes! :biggrin:
so the LHS of the original equation is … ? :smile:
I think I get it, Thanks a lot.
\tan \left (\theta_n-\theta_{n-1} \right )=\frac{1}{2n^2}
and then
\theta_n =\tan^{-1}\left (\frac{1}{2n^2} \right )+\theta_{n-1}
and then
\theta_n =\theta_{0}+\sum_{k=1}^{n}\tan^{-1}\left (\frac{1}{2k^2} \right )
By knowing that special solution mentioned in post #1, I can derive the formula in post #3. What If I didn't know that special solution?
hmm :confused:
putting ao = 0 or 1 gives an = 1 + 2n or -1/(1 + 2n)
and putting ao = ±i looks interesting :rolleyes: (i haven't followed it through :redface:) …
do either of those help? :smile:
Putting a0=0 in which equation?
Mathematica's …
OK. So far, first I 'guessed' a special solution, then I derived the general solution by using that special solution. Is there any analytic way to find (not guess) a special solution?
