What does Maxwell's equations mean?
Maxwell's equations describe the fundamental principles of electricity and magnetism, illustrating how electric and magnetic fields interact. The equations involve various vector fields, including electric field (E), magnetic field (B), electric displacement field (D), and H-field (H), with specific symbols denoting derivatives and charge density. The discussion highlights that these equations imply the propagation of light, linking them to the phrase "Let there be light." The conversation also touches on the significance of these equations in understanding electromagnetism and their historical impact on theories like relativity. Overall, Maxwell's equations are presented as a complex yet fascinating subject worthy of in-depth study.
zafari
I need some help figuring out what these formulas mean and what they relate to. All I know is the 'upside-down triangle' symbol is known as a "Del", and it's used in vector calculus.
Before the list of equations, it says "And God said...". After the list of equations, it says "...And there was light."
I'm guessing they might spell something in Latin which translates to "Let there be light", aka, "fiat lux".
Any help is appreciated!
These formulas are collectively called Maxwell's equations, and they describe electricity and magnetism. One solution to these equations describes the propagation of light. Hence, if God had "said" Maxwell's equations, then light would exist as a consequence of those equations.
Ah, that makes sense. Can you describe what the variables mean? I am familiar with rho as density, and it seems like the -aB/at and aD/at seem to be derivatives taken with respect to t (time?), but that's about it.
Yeah, it's a little hard to read the symbols; let me write out the equations here.
\nabla \cdot D = \rho \\<br /> \nabla \cdot B = 0 \\<br /> \nabla \times E = -\frac{\partial B}{\partial t} \\<br /> \nabla \times H = i + \frac{\partial D}{\partial t}
The symbol \partial denotes partial differentiation--a derivative of a function of multiple variables that holds all others constant.
t is time. \rho here is the free charge density. We say "free" because charge can come from two sources; in particular, this charge density excludes charge that came from polarization of matter (where something that was neutrally charged gains positive charge in one place and negative in the other). Charge density that arises in this way is typically called "bound" charge.
i is the free current density, and there can be bound current density in the same way. Together, \rho and i are the "sources" of electromagnetic fields, E, D, B, H. E,D have to do with electric fields. E is usually called the electric field, while D is sometimes called the "electric displacement field". Usually, B is called the magnetic field nowadays, whereas H has a few different names, but it's often just referred to by its symbol as "the H-field".
E,B,D,H are vector fields, and the \nabla \cdot and \nabla \times describe how the derivatives of these fields must relate to the sources or to other time derivatives of fields.
This image appears to be in a specific set of units; often, you might see Maxwell's equations in SI units instead, and you'll see constant factors of \epsilon_0,\mu_0 in places. These just make the numbers work. Finally, you might see Maxwell's equations in vacuum, which simplify things considerably: without matter that can be polarized, D and H basically reduce to E and B respectively. There are also integral forms of Maxwell's equations, which are generated through a nifty piece of mathematics called Stokes' theorem, but they say the same thing.
That's the 30-second explanation of Maxwell's equations in a nutshell; wikipedia would do a far better job of explaining them than I ever could. The classical theory of electromagnetism is one of the most fascinating aspects of physics, and there's quite a bit of history to it that has helped shape our understanding not only of light but of space and time. Maxwell's equations predict that the speed of light is constant regardless of one's speed, and that helped motivate the theory of relativity. It is a robust, elegant theory and worthy of many hours of study, in my opinion.
Whoa, that actually makes sense. It definitely seems like a very complex concept, which makes it all the more interesting. Thanks for the explanations, I would be very lost without them.
