Help creating constant-speed linear motion
To achieve constant-speed linear motion for a plate at 100 mph while maintaining high torque and efficiency, a ball screw assembly is recommended due to its potential efficiency of up to 90%. The setup involves moving the plate in a straight line for 1-2 feet before it bends into a "C" shape and transitions into a circular path around a rotor. This design minimizes drag and conserves energy, especially with a second plate moving in the opposite direction to optimize repositioning. Lightweight modern components, such as magnetic gears, are also suggested to enhance performance. The discussion emphasizes the need to balance efficiency and torque while meeting specific speed requirements.
xatz
I want to move a plate at a constant speed in a straight line, and to do so in as efficient a way as possible with high torque involved.
What would be a good method to accomplish this? The problem is that both torque and efficiency are very important.
How about a lead screw or ball screw assembly?
The HP involved is 3, and of this motor input, I'd like to get 2.7 HP's worth, but 2.5 HP is acceptable. There is also a specific speed the plate must move at, which is a constant 100 mph in a straight line for 1-2 feet.
After this linear movement, the plate will bend into its four sections, forming a "C" shape, and then will move in a circular path around a rotor back to its original position to repeat the process. This path and form is used to minimize drag while still moving 100 mph and to cost a lot less energy to do so. There will be a second plate in use that will be moving at an exact opposite point so energy isn't wasted during this re-positioning of the first plate.
I would also like to use lightweight and efficient modern parts such as magnetic gears, which may be required to get the best results.
Well, lead screws tend to be inefficient and to wear out quickly. I updated the info of the requirements in a new post so it will be more clear what's needed. Ball screws can be up to 90% efficient, which is great, but I'll have to see if they can be used for the high speed requirement, though.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
