Solving IVP for Second-Order Differential Equation: x^2*y+4*x*y'+4*y=0
  • Thread starter Thread starter BobMarly
    Ivp
BobMarly
Not sure of solution for IVP
(x^2)*y"+4*x*y'+4*y=0
y(1)=1 y'(1)=2
Start with r(r-1)+4r+4=0
then (r^2)+3r+4=0
get (-3+/-7i)/2
Leads to y=C(1)e^(-3t/2)cos(7t/2)+C(2)e^(-3t/2)sin(7t/2)
More y'=... one large formula
Am I on the correct track, is there something I missed, or is there a shortcut here
it seems that by putting in IV's, it doesn't lead to anything clean
y(1)=1 y'(1)=2
then (r^2)+3r+4=0
get (-3+/-7i)/2
First off, does this function satisfy your differential equation? If so, you have the right general solution.
Next evaluate your solution and y'(t) at 1 and solve for the two constants. The check there is verifying that y(1) = 1 and y'(1) = 2.
At this stage in your learning, you should get in the habit of verifying that solutions you find are actually solutions. You've already done all the hard work, so checking your work is simply a matter of 1) showing that your solution satisfies the DE, and 2) that your solution and its derivative satisfies the initial conditions.
How do I know it satisfies the equation?
y(1)=1 y'(1)=2
then (r^2)+3r+4=0
get (-3+/-7i)/2
No it doesn't.
You are confusing the characteristic equation for constant coefficient DE's with this problem. The "solution" you propose is what you would get for those roots of r if this were a constant coefficient equation. But it isn't. This is an Euler equation and you get that indicial equation by looking for a solution ##y = x^r##. Look in your text for the form the solution takes for complex conjugate roots. It will have x's times cosines and sines of ln x's.
In fact, the reason the "Cauchy-Euler" equation is as simple as the equation with constant coefficients (and easily confused with it) is that the substitution t= e^x converts the Cauchy-Euler equation Ax^2d^2y/dx^2+ Bx dy/dx+ Cy= 0 into the 'constant coefficients' equation Ad^2y/dt^2+ (B- A)dy/dt+ Cy= 0.<br /> The two have the same characteristic equation. In your case the constant-coefficients solution is<br /> e^{-3t/2}(C_1cos(7t/2)+ C_2sin(7t/2))<br /> so that the solution to the original CauchyEuler equation is <br /> e^{-3(ln(x))/2}(C_1cos(7ln(x)/3)+ C_2 sin(7ln(x)/3))= x^{-3/2}(C_1cos(7ln(x)/2)+ C_2sin(7ln(x)/2))
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
