Numerical method for finding charge density on a conductor
The discussion focuses on developing a numerical method to determine charge density on a deformed spherical conductor with axial symmetry. Previous approaches, such as simulating N charges on the surface, were slow and lacked precision. The proposed method involves breaking the surface into coaxial circular rings to compute a mutual capacitance matrix, but challenges arise due to logarithmic divergences in capacitance calculations. An alternative approach suggests using the known potential of a charged ring to derive an elastance matrix, allowing for efficient simulation of charge flow until equilibrium is reached. The goal is to explore the relationship between curvature and charge density, particularly for non-uniform shapes.
bcrowell
Staff Emeritus
Insights Author
I'm interested in working out an efficient and precise numerical method to find the charge density on a conductor with an axially symmetric shape that is essentially a deformed sphere. (I have in mind something like r(\theta)=\sum \beta_\ell P_\ell(\cos\theta), where P is a Legendre polynomial.)
My previous work on this involved putting N charges on the surface and simulating their motion until they reached an equilibrium. This is slow and doesn't give a high-precision approximation to the continuous case.
There's the relaxation method for solving the Laplace equation on a grid, but that seems to apply when the potential is known on a boundary. I think my boundary would consist of the conducting surface plus another surface far away, but I don't know a priori the potential difference between these two. The usual relaxation method would involve a 3-dimensional Cartesian lattice of points, which would not exploit the symmetry of the problem. (But I could probably fiddle with it somehow to make it effectively a 2-d grid.)
It seems like a better way to go would be to break down the surface of the grid into n coaxial circular rings, find their mutual capacitance matrix C, and then use Q=CV, where Q is a vector of the n charges and V is a vector of their n potentials. Since I know V (a vector with all its n components equal to some arbitrary value), I can find Q. The problem I'm running into here is that the mutual capacitances that are the elements of C all diverge logarithmically. This makes it all kind of a mess compared to the nice simple case of the mutual *inductance* of two coaxial loops of unequal radius, which is finite and can be found using elliptic integrals. I could do it for finite-thickness loops, but then maybe it gets messy. Possibly if I can characterize the logarithmic divergence properly, I can just renormalize it out using some approximation...? This method would otherwise be nice, because once the C matrix was found, it would be very efficient.
Another possibility would be to find the field of a loop of charge and simply simulate the flow of charge between loops until they reached equilibrium. The problem is that the field of a loop of charge is probably not easy to calculate with good numerical precision at an off-axis point.
Any suggestions?
It turns out that you can get the potential of a charged ring in terms of an elliptic integral. The following is from online lecture notes by Vittorio Celli:
First we review the similar problem of computing the electrostatic potential
of a uniformly charged ring, which is
<br /> <br /> \Phi (\rho ,z)=\frac Q\pi \int_0^\pi \frac{d\phi ^{\prime }}{\sqrt{%<br /> <br /> r^2+a^2-2a\rho \cos \phi ^{\prime }}} <br /> <br />
The integral is transformed to standard form by the change of variable
\phi^{\prime }=\pi -2\varphi, \cos \phi ^{\prime }=2\sin ^2\varphi -1, so that
<br /> \sqrt{r^2+a^2-2a\rho \cos \phi }=\sqrt{a^2+r^2+2a\rho }\sqrt{1-\frac{4a\rho <br /> }{a^2+r^2+2a\rho }\sin ^2\varphi } <br />
The result is
<br /> <br /> \Phi =\frac{2Q}{\pi \sqrt{a^2+r^2+2a\rho }}K\left( \frac{4a\rho }{%<br /> <br /> a^2+r^2+2a\rho }\right) <br /> <br />
where K(m) is the complete elliptic integral of the first kind K(m)=\int_0^{\pi /2}\frac{d\varphi }{\sqrt{1-x\sin ^2\varphi }}
There are also other ways of expressing this, such as with a series involving Legendre polynomials: http://leofangyaolung.files.wordpress.com/2012/05/potential1.pdf (discusses both the disk and the ring). This approach is also in Jackson.
This would seem to make it pretty straightforward to calculate the mutual capacitances, although there would still be the issue of the logarithmic divergences.
Electrostatics is strictly similar to gravitation, and algebraic solutions exist for the gravitation field of a flattened sphere; the field is expressed as a sum of (Bessel?) special functions.
This is needed to find the orbit of satellites around our Earth, especially low-orbiting (800km) satellites with inclination nearly polar like 98°, where the equatorial bulge let's the orbit's plane rotate by 1 turn in 1 year, so the satellite passes always at the same Solar time over the ground.
Cool stuff -- both the math (which I wouldn't have thought was doable in closed form) and the application. But I don't think it directly helps me, since my shapes aren't necessarily ellipsoids, and the charge density (which is the unknown I'm trying to find) is nonuniform. The charge density happens to be known in closed form for a conducting ellipsoid: http://math.stackexchange.com/quest...-proportional-to-fourth-power-of-the-distance My motivation for studying this numerically is to see if there is a strict relationship between curvature and charge density, as there is for an ellipsoid and for certain other special shapes: https://www.physicsforums.com/showthread.php?p=4047030
It sounds like you might be able to solve that nicely using Conformal Mapping: http://mathworld.wolfram.com/ConformalMapping.html
I have no experience with the technique but was thinking of using it to solve a similar type of problem years ago. It requires you to cast the problem into a representation using complex numbers. There are a couple of books to recommend (which I have) but at the moment I don't have the references.
Yeah, unfortunately I think that only works for a problem that reduces to a plane. My problem is effectively two-dimensional because it has cylindrical symmetry, but it doesn't reduce to a plane.
I think I have a strategy that works. Since we have a closed-form result for the potential of a ring, it becomes trivial to compute the elastance matrix (inverse of the capacitance matrix), P. The diagonal elements of this matrix are infinite if the rings have zero thickness, but we can treat them as having a thickness equal to the separation a between neighboring rings. The diagonal elements then become something more like (I think) (k/r)\ln(r/a), where r is the radius of that particular ring.
Once I have the elastance matrix, I can put some charge on each ring, and then in O(n^2) time I can find the potential difference between neighboring rings. Taking some finite resistance between neighbors, I can simulate a current, and iterate until I get to equilibrium.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
