Are Sigma Algebras Unique for a Given Set?
  • Thread starter Thread starter ChemEng1
    Set Sigma
ChemEng1
Is there only 1 σ-algebra generated for a set?
Consider M={1,2}. Ʃ(M)={∅,M} satisfies the definition of a σ-algebra. However, Ʃ(M)={∅,{1},{2},{1,2}} also satisfies the definition of a σ-algebra. However, the way that my text presents these problems (Prove that the σ-algebra generated...) implies that they are unique.
Any help would be appreciated.
For every set M, there are at least two sigma-algebras over M, namely {∅, M} and P(M), the power set of M, these are called trivial algebras.
However, if N is a subset of P(M), there is a unique smallest sigma-algebra over M, that contains every element of N. This is called the sigma algebra generated by N. I think, this is what your book refers to.
Hi, ChemEng1 : like csopi said, given a subset N of M , with N≠∅ and N≠M, there
is only one σ-algebra generated by N . By construction, this will be the intersection
of all σ-algebras containing N. If , instead of N , you had two or more subsets, then the
σ-algebra would contain the union of all sets, their intersection, their complement, etc.
These two definitions of minimality are equivalent. Basically, if N is in the algebra, then
so is its complement. If sets A,B are in the sigma algebra, then so are A\/B , A/\B,
A\B , etc. This extends to 3-or-more sets.
Thanks for confirming this. I spoke to the professor about this. His comment was "My native language is Russian. Questions clarifying how I use articles are completely fair."
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
