Why is my if statement executing when its false
  • Thread starter Thread starter ProPatto16
    If statement
The issue arises from using a single equals sign in the if statement, which assigns the value true to the variable instead of comparing it. This means the condition always evaluates to true, leading to the unexpected execution of the second if block. The correct syntax for comparison is to use a double equals sign (==). Additionally, using just the variable name in the if statement is a more concise way to check its truthiness. Correcting this will resolve the problem of the else block not executing as intended.
ProPatto16
quick question, not sure why i can't work this out.
in the following code my if statement executes, but as far as i can see i have set the boolean so that it shouldnt.
Code:
public void actionPerformed(ActionEvent e)
                   boolean contains = false;
                   for (int i = 0; i < studentStrings.size(); i++)
                        if( studentStrings.get(i).contains( enterID.getText()))
                            System.out.println( " get constains executed");
                            contains = true;
                    if ( contains = true)
                        updateOldRecord();
                        System.out.println( "if executed");
                    else
                        newRecord();
                        System.out.println( "else executed");
you can see there are 2 ifs and one else. When and if the first one executes it should set the boolean contains to true. then if boolean contains is true my second if should execute and not my else. and if the first if doesn't execute the boolean should still be false so my else will execute. the system.print methods are just so i can see which ones are executing.
in the for statement the idea is i look for a string in the arrayList that is entered into a student ID text field. if the ID already exists it updates that student, if not it creates a new record.
the problem is whether or not that first if statement executes, only my second if executes, never the else.
so if my jtextfield has an existing ID number executed i get
get contains executed
if executed
and if it does not contain an existing ID then boolean should remain false and then only execute the else but i get
if executed.
i don't know why my if statement arguments arent working?
thanks
You are missing an equals sign. If (contains = true) sets contains equal to true and then tests whether it is true. If (contains == true) just tests whether contains is true without changing its value.
Code:
There is a difference between assignment and comparison.
The expression of assigning a boolean can be treated as a boolean.
Code:
boolean b = false;
if( b = true) //expression in () sets b to true and evaluates to true
    System.out.println( "THIS LINE WOULD GET PRINTED");
As an aside, one may write
Code:
if(b == true)
more concisely as
Code:
if(b)
Thanks, knew it would be simple!
