Transmission line/reflection coefficient question
The reflection coefficient can be calculated using the formula gamma = (ZL - Z0) / (ZL + Z0), even when ZL has both real and imaginary components. For Z0 at 50 ohms and ZL at 125 + j40, the calculation yields a complex reflection coefficient. This indicates the presence of inductive or capacitive reactance, depending on the sign of the imaginary part. The formula remains valid regardless of the nature of the impedance. Understanding complex reflection coefficients is essential for analyzing transmission line behavior in various scenarios.
Robismyname
reflection coefficient gamma = ZL-Z0/ZL+Z0.
My question is can you calculate the reflection coefficients when ZL has a real and imaginary?Lets say that Z0=50 ohms and ZL = 125 +j40.
All my example in books show ZL and Z0 being real only. Well how do you determine reflection coefficients when the ZL ha real and imaginary and Z0 is 50 ohms?
The formula still works. You get complex reflection coefficients indicating the presence of inductive (+imaginary) or capacitive (-imaginary) reactance.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
