Spacecraft Re-Entry: High Freq Comm & Plasma Frequency
  • Thread starter Thread starter Aniket1
    Spacecraft
Communication blackouts during spacecraft re-entry occur due to high-density plasma that forms around the vehicle, preventing radio waves from penetrating. The plasma frequency is a critical factor, as it determines which frequencies can pass through. Higher frequency communication has been suggested as a potential solution, but practical limitations and the physics of plasma interactions complicate this approach. The discussion highlights the need for further research into alternative communication methods that could mitigate the blackout issue. Understanding plasma behavior and its impact on communication is essential for improving spacecraft re-entry technology.
Aniket1
I recently read about the communication blackout during a spacecraft re-entry.. The reason given was the high density plasma formed whose plasma frequency is such that the communication waves do not penetrate it. Why don't we use a higher frequency for communication which is sufficient to pass through the plasma?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
